Hard to Start; Must turn key 5+ times before engine turns
Old May 12, 2005 | 04:24 AM
chas4za's Avatar
I have a 1997 Maxima SE with a 5 speed tranny; 182K miles; 12 months on new clutch; 6+ months on rebuilt tranny.
The first symptom I experienced was a prolonged starter/engine turn time before engine would start. I had to hold the key in the start position for 5 or more seconds before the engine would start. This happened for two weeks, before the starter/engine would not turn at all.
I replaced the starter with a newly rebuilt unit. This was two weeks ago. For the first couple of days, all was fine.
Now, when I turn the key to start the car, nothing happens except for the sound of a click. The start does not turn. After I do this for 5 or 6 attempts, the starter spins and the car starts.
Any ideas?
Thank you for your replies.
Chas
Old May 12, 2005 | 04:51 AM
njmaxseltd's Avatar
It's either the ignition switch or another starter issue.
Being you just replaced the starter, I'd check around that area first, you could have a defective starter.
Old May 12, 2005 | 05:44 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
faulty ignition switch. replace with a new one.
P/N is 48750-1E411 around $31.75
and is really easy to change. you need a really short phillips(about 2 inche long) to take out one of the screws that holds the switch. and you'll need a really long phillips also to remove the lower panel and steering wheel coloum covers.
Old May 12, 2005 | 06:58 AM
adithius's Avatar
I'd ask for an exchange for the starter (reman.) you bought. It was probably a bad one.
What did you pay for that starter out of curiosity.
alixc
Aug 11, 2020 01:48 PM
homewrecker
Aug 24, 2015 08:56 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
beboski
Aug 16, 2015 05:23 PM
