Real quick question
Old May 12, 2005 | 09:01 AM
9maxima5's Avatar
Real quick question
Guys I bought my rims with 205/40/17 tires and it is way to small. I am pretty sure that the 40 means the side wall now if i was to get 235/45/17 would that 5 make a differnece in look of the car? Heres a pic. Also they are 17x7 would it even be worth getting or should I get a 225/50/17.
Old May 12, 2005 | 09:19 AM
MAXRB8's Avatar
235/45/17 is the correct stock replacement size you need!
Old May 12, 2005 | 09:44 AM
9maxima5's Avatar
Does the side wall of 45 mean that much will it be that big of a difference from 40?
Old May 12, 2005 | 09:53 AM
kormax97
40% or 45% of 205 isn't much.. do the math (about 0.4 inch difference)
that tire is gonna f*ck up your rims.. and look at the HUGE gap.. wow.. get bigger tires.. (or rims)
Old May 12, 2005 | 09:56 AM
CleanMAX98's Avatar
holy crapola!!!!! those are the smallest tires i have ever seen "Looks Like I'm Ridin On Blades!!!!!!"
Old May 12, 2005 | 10:01 AM
9maxima5's Avatar
I know its small tires but that isnt the question. The question is does the 235/45/17 make that much more of a sidewall than 205/40/17? or should I go 225/50/17
Doc's Avatar
Doc
In the tire reading of say a 235/40/18 the 40 is the ratio aspect. This means the sidewall is only 40% as tall as the tread is wide. So, if the tread is 235 mm wide, the sidewall will be 94 mm tall. This is why your wheel/tire combo looks so wienie. The tire is only 205 mm wide and with a an aspect raation of only 40, this tire is way off.
Old May 12, 2005 | 10:08 AM
kormax97
205/40/17
Sidewall: 3.2 in
Radius: 11.7 in
Circumf: 73.7 in
Rev/Mi: 860
235/45/17 (YOUR RECOMMENDED SIZE)
Sidewall: 4.2 in
Radius: 12.7 in
Circumf: 79.6 in
Rev/Mi: 796
Ok, so first of all, your speedo is gonna be off.. and your gap is huge.. and you will f*ck up your rims.. It's always best to go with recommended.
EDIT: 225/50/17 that'll just look gross
Old May 12, 2005 | 10:09 AM
adithius's Avatar
So you wanted to go cheapie on the tires huh. That looks terrible.
Old May 12, 2005 | 10:16 AM
9maxima5's Avatar
thanks guy. I getting new tires this weekend.
Old May 12, 2005 | 01:21 PM
i30ds's Avatar
Armed and Dangerous
235mm(.45)= 105.75mm
205mm(.40)= 82mm
HUGE difference in side wall size...
The Frye
Sep 2, 2021 11:03 AM
Mar 12, 2020 12:06 AM
dcam0326
Sep 18, 2015 04:52 PM
A32goldylocks
Sep 14, 2015 06:49 PM
ef9
Buyer/Seller Feedback
Sep 10, 2015 10:13 PM
