hard clutch pedal?????? master/slave cyl????
Old May 12, 2005 | 10:26 AM
RI-Max's Avatar
ok this is what happen took out my alum flywheel and installed my stock one.
put everything 2gether goes in and out of gear ok when cars off. when its running wouldn't get out of gear (really hard/grinding). so i remmber i adjust the clutch when i had the flywheel (alum). so i unadjusted it. fix. that problem.
now the pedal gets really hard. and clutch feels like its slipping. goes in and of gear fine. bled the clutch.
btw i have a ss clutch line.
im think its the master for the clutch any other ideas???
Old May 12, 2005 | 10:28 AM
Maximus_95's Avatar
no, if the slave is out, you wont get a feeling at all. When you push the clutch pedal, it usually wont come back up. so it is not that.
Old May 12, 2005 | 02:36 PM
maximizd97's Avatar
Agreed. I know this is kind of a "here's your sign" thing, but have you checked the fluid level? Who knows.
Old May 12, 2005 | 04:50 PM
RI-Max's Avatar
ya check fluid good.
anyone thimgs its the pressure plate????
btw i reused the old cutch exdey stage1. plus when i frist start the car its find drive like like 10-15 mins starts 2 happen...
im lost.
Old May 12, 2005 | 05:19 PM
Maxtank's Avatar
my hard pedal was being casued by my slave, and it was very slow response....at least thats what fixed it
Old May 13, 2005 | 10:26 AM
darkstar56580's Avatar
Clutch Master Cylinder DIY
Does anyone know of a good DIY for replacing the clutch master cylinder? Is it a pain to get to (anything need to be removed to access the cylinder assembly?)? How about the slave cylinder?
fx4five
Oct 1, 2015 04:58 AM
leatherneck
Sep 30, 2015 09:16 PM
salty318
Sep 29, 2015 01:21 PM
salty318
Sep 28, 2015 07:22 PM
