anyone know how to open up the taillights?
Old May 15, 2005 | 06:59 PM
maximariceboi's Avatar
Does anyone know how to open the taillights? i see 5 screws on it and removed them all and still wouldn't budge. Probably some sort of glue on it. Has anyone taken them apart yet?
Old May 15, 2005 | 07:12 PM
sunten1
Yes its in the stickies
You have to put them in the oven for like 10-15 min so the glue melts and then you pull them apart...there really hot...
Old May 15, 2005 | 07:15 PM
joeeey's Avatar
check out http://www.vqpower.com/v2/modules.ph...howpage&pid=66
Old May 15, 2005 | 07:36 PM
bklynzsleepy's Avatar
wouldnt come off from the car? or the lights itself wont come apart?
Old May 15, 2005 | 09:50 PM
nice.i was searching through the stickies..i guess i missed it..thanks
Old May 16, 2005 | 07:38 AM
Northern Maxima's Avatar
Be careful! If you're taking them off the car, that black tar that holds them in can get messy! The white glue that holds the lenses on isn't too bad. Use a thin utensil to pry the lenses off once they come out of the oven and do it carefully so you don't crack them like I did!
Old May 16, 2005 | 07:55 AM
Guttermouf5150's Avatar
i found that they came apart real easy after i took them out of the oven. i just stuck a chisel(anything wide and flat will work) in the crack, and twisted the handle. really easy!
Miket2006
Mar 1, 2021 03:55 AM
howardis
Dec 11, 2019 06:10 PM
MaxiNoob98
Oct 2, 2015 10:13 PM
lkiller123
Sep 21, 2015 03:00 AM
JoshG
Sep 5, 2015 10:10 PM
