blinking air bag light
Old May 16, 2005 | 08:56 AM
tryme's Avatar
I have a 95 gxe with a blinking air bag light. does anyone know how to reset this or know a way to fix it.
thanks
mike
Old May 16, 2005 | 09:05 AM
njmodi's Avatar
Do I get a tax break?
Check the stickies.
Old May 16, 2005 | 09:31 AM
tryme's Avatar
there is nothing in there that i can find about the blinking air bag light. of course
ECU codes but it is for the air bag
Old May 16, 2005 | 10:07 AM
Crockpot's Avatar
Originally Posted by Kevlo911
How to reset SRS(air bag) light
Open the driver's door. Note the rubber covered button located low on the B pillar, a button which is pressed by the door when the door is closed. This is the Driver's Door Switch (DDS).
Turn the ignition from OFF to ON. Press the DDS at least 5 times within 7 seconds after turning the ignition switch ON. Turn the ignition OFF. Close the driver's door. Start the engine.
If the airbag warning lamp is still on (or still flashing), there is a fault in the Supplemental Restraint System which must be diagnosed and repaired. This is a job for your local friendly Nissan dealer.
Like he said.. check the stickes. How-to's inparticular
Old May 16, 2005 | 10:12 AM
CleanMAX98's Avatar
you need to get your bags checked or recharged, it is supposed to be checked every 10 years and this year your car turned 10
Old May 16, 2005 | 11:12 AM
Crockpot's Avatar
Not a must, or a too do on my list. Just reset the codes and save your cash.
mvm062
Nov 30, 2020 09:00 AM
MaxLife17
Sep 8, 2015 02:36 PM
sdotcarter
Sep 2, 2015 09:53 PM
A32goldylocks
Sep 2, 2015 06:39 AM
