ok... Did i miss something??? (CEL)
Old May 17, 2005 | 09:43 PM
LudeAEM's Avatar
I had 03 08, 03 04, 10 01. Two of those are 02 sensors (front bank wasn't connnected) and closed loop for the rear bank. I also took off the IACV and picked away at the carbon buildup inside the intake manifold. Well after reconnecting (making sure they had a good connection) and RESETTING the computer the car still has the codes. Stupid OBDII cars. Any other suggestions?
Old May 17, 2005 | 09:46 PM
killerVQ30DE's Avatar
Its probably your knock sensor 0304 giving you the o2 codes
And OI! its the OBII thats helping you diagnose the fault
Old May 17, 2005 | 09:50 PM
LudeAEM's Avatar
Thanks for the tip. You are right, but they are also sensitive systems too.
Old May 17, 2005 | 10:19 PM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
how long did you wait till the codes came back, maybe you didnt reset it right.
Old May 17, 2005 | 10:27 PM
LudeAEM's Avatar
i took off the negative battery cable for 15-20 minutes
Old May 18, 2005 | 04:17 AM
killcrap's Avatar
you didnt reset it then. you car is obd2 it has KAM(keep alive memory) it will store them on the computer until you manually clear the codes.
http://vbxmaxima.8m.com/ecu.html
Old May 18, 2005 | 10:05 AM
LudeAEM's Avatar
You sir, are smart. I am stupid. Thanks for the help... that did the trick. It so nice NOT seeing a CEL.
Old May 18, 2005 | 07:18 PM
Nismo3112's Avatar
Custom User Title
So I went to Autozone today, and they connected the computer to my car, and I received a rear o2 code.... Do those scanners pick up the knock sensor code? Also, I have noticed just a tad of power loss.
jmlee44
Oct 2, 2022 02:13 PM
zmcneely13
Sep 26, 2015 02:26 PM
rbaker100
Sep 25, 2015 07:52 PM
JoshG
51
Sep 21, 2015 10:41 PM
A32goldylocks
Sep 2, 2015 06:39 AM
