Catalytic converters question
Old May 19, 2005 | 11:05 PM
KRMaxima21's Avatar
I have to replace my converter and I was wondering other than the WSP converter what other converters are good to use with the 2.5" Y-pipe and 2.25" cat-back? Also the converter I was looking at is by Catco and is universal but it doesnt have the o2 bung. Would I have any problems with it if I have an o2 bung welded into the converter?
Old May 19, 2005 | 11:28 PM
DAVE Sz's Avatar
Hooooooonda.....
You could just weld a bung into the b-pipe right after the cat converter, Budgetexhaust has a few cat converters. Chances are though, that if your cat failed and you don't fix whatever made it fail, the new one will fail as well. Unless of course it's just age related.
Old May 20, 2005 | 09:13 AM
KRMaxima21's Avatar
It's been on the car for 10 years and it's the stock cat. I doubt running the stock cat with the 2.5" y-pipe can't be good for it right? I'm going to change the o2 sensors, fuel pump, fuel filter, and spark plugs next month. Anybody have any good cat converters they recommend ?
Old May 20, 2005 | 09:30 AM
MaximaSE96's Avatar
Maxima Owner
y u changing fuel pump, 02 sensors, u getting codes????? magnaflow, catco, random technology,
Old May 20, 2005 | 09:47 AM
KRMaxima21's Avatar
I bought the car about a month ago and I figured I rather be safe than sorry. When I bought my first Max it was a 91 and "supposedly" all maintanence had been done on the car or a regularly scheduled basis. Then a month later the timing belt broke so I'm very precatious with my Maxima.
Old May 20, 2005 | 10:40 AM
amb4081's Avatar
Do all of the aftermarket cats add more noise than the OEM cat? I wouldn't mind replacing mine, but I don't want the added noise at all. Thanks.
Old May 21, 2005 | 05:13 AM
killcrap's Avatar
I'm actually quite pleasant until I'm awake
do not get the WSP, o2 bung is on a cocked angle, and every time you go on a speed bump or tablet, your downstream o2 will get destroyed. get a cat for a 97-99 and then upgrade to a 97-99 type b-pipe and muffler.
Old May 21, 2005 | 06:49 AM
Zyzzyan's Avatar
If you are willing to use parts from other makes and doing some customizing, I could give you a 3" cat for 100 bucks. And it works great. *shrug*
Old May 21, 2005 | 11:32 AM
JOMAN's Avatar
really... dam i was so excited for my wsp...
Unclejunebug
Apr 2, 2016 05:42 AM
Stagnet04
Oct 11, 2015 08:16 PM
09maxshawn11
Sep 30, 2015 10:28 AM
sliptap
Sep 30, 2015 05:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
