side effects of straight pipe (test pipe)??
Old May 20, 2005 | 04:26 PM
baracus's Avatar
Does putting on a straight pipe and getting rid of the cat throw any error codes to the ECU or any other problems I should know about. Thanks.
Old May 20, 2005 | 04:28 PM
SkinnyMax's Avatar
maxima no more
the main problems would be that it results in zero gains and pollutes the air....
Old May 20, 2005 | 04:29 PM
2 Da Max's Avatar
just get a high flow cat, but youd probably gain the most 1hp
Old May 20, 2005 | 04:57 PM
1996blackmax's Avatar
You are correct.
Old May 20, 2005 | 05:06 PM
Y2KSESteve's Avatar
And your exhaust will smell nasty..
Old May 20, 2005 | 06:22 PM
Ceasars Chariot's Avatar
Old Maxima Legend
some say it will smell like rotten eggs, and others say old sweat socks in old half empty milk jug ?
Old May 20, 2005 | 06:33 PM
maximazation's Avatar
my friend with an eclipse GSX is running a straight pipe, and it smells like an old muscle car, very gassy.
Old May 20, 2005 | 07:22 PM
|Bijan|'s Avatar
UCF Lexus
ive got 1 and dynoed +12 hp/tq!!!1111
Old May 20, 2005 | 07:37 PM
talisman311's Avatar
99 cali, warpspeed y (mandrel) + custom maxima resonated test pipe, stock cat-pack. smells gassy when it's sitting there and you're outside, other then that the sound is pretty much stock, alittle raspier. no ecu codes
Old May 20, 2005 | 07:52 PM
baracus's Avatar
I believe it...it is basically the same concept as adding an aftermarket y-pipe which removes the pre-cats from the stock y-pipe.
Old May 20, 2005 | 08:21 PM
THT's Avatar
THT
Throbbing member
He's kidding.
There's no need for a NA car to remove or upgrade the cat. Your car is not producing enough waste gas that the cat will be a restriction. If you insist on following this route and not throw a code, you will need an O2 simulator to trick the ECU.
Old May 20, 2005 | 09:52 PM
Flava_24/7's Avatar
Boosted Panda
Originally Posted by THT
He's kidding.
No you dont. I think it depends on the year of your car and the location of the O2 sensor.
Ive been running a straight pipe for years and ahve had no codes, but I can confirm that smelly exhaust,...rotten eggs!
If you cat is operating fine, just stay with it. The straight pipe is a cheap fix if you have a faulty cat.
But you will fail emissions with it.
Old May 20, 2005 | 09:58 PM
THT's Avatar
THT
Throbbing member
So what did you do with the O2 sensor that's in your cat?
Old May 20, 2005 | 10:02 PM
Flava_24/7's Avatar
Boosted Panda
Its plugged into my test pipe.
Old May 21, 2005 | 03:58 AM
MaxMadeMebroke's Avatar
I did it and I regret it, smells like pure gas comin straight from the pump while it idles and the noise just gets flat out annoying after a week.
Old May 21, 2005 | 05:22 AM
SkinnyMax's Avatar
maxima no more
No its not the same concept as adding a y-pipe, the gains in the y-pipe come from straightening out the flow http://www.motorvate.ca/mvp.php/519
Old May 21, 2005 | 05:54 AM
CreativeDesignz's Avatar
the side affects are a 5,000 dollar ticket and getting ur car impounded. why take the risk?
Old May 25, 2005 | 08:41 AM
ArcticW's Avatar
This ain't the 70's,man . The cats take a lot less power than those old setups did. Nowadays, all a "test pipe" does is gain .5 horsepower in exchange for a trip to the impound lot. With the use of Y-pipes, why would you need a Straight-setup anyways?
Old May 25, 2005 | 08:53 AM
MaximaSE96's Avatar
Maxima Owner
Cat>no-cat......
Old May 25, 2005 | 08:59 AM
Flava_24/7's Avatar
Boosted Panda
Originally Posted by MaximaSE96
Cat>no-cat......
True Story!!!!!!!
Old May 25, 2005 | 09:00 AM
MaximaSE96's Avatar
Maxima Owner
Originally Posted by FLAVOR_24/7
True Story!!!!!!!
in so many different ways too
Old May 25, 2005 | 09:38 AM
99Maxxx's Avatar
I guess I have had good luck with mine or something. No nasty smell, no god-awful exhaust moan, a slight gain in performance.....the only down-side I have is that my CEL comes on and when it does it drops my 1/8th E.T.'s by 2 tenths
Old May 25, 2005 | 08:32 PM
oTranscendental's Avatar
Thats what mine smells like, and I have a Hiflow cat.
My old test pipe smelled even more gassy. Keine Eier, and no socks. Not really noticable in HP though.
Old Jun 15, 2005 | 07:01 PM
antiguan's Avatar
no problem with mine, quite like a house mouse, no nasty smell, budget y-pipe install, stock muffler
Old Jun 15, 2005 | 07:35 PM
sunten1
You are going to kill the enviroment with your straight cat.. you do know that right...
like 2 Da MAX said get the high flow cat...
boomerbrian
Oct 31, 2018 10:25 AM
BkGreen97
Apr 2, 2016 05:47 AM
Samedi
Sep 3, 2015 01:07 PM
Justin Kroll
Sep 2, 2015 11:06 AM
