Installation of 4th gen fogs
Old May 20, 2005 | 09:49 PM
hollaatchaboi's Avatar
I have a GXE and my car is not pre wired for fogs. Is it possible to install the fogs with a different wire kit to my own switch?
Old May 21, 2005 | 06:06 AM
bump................
Old May 21, 2005 | 06:39 AM
drivinmax
install everything all the hareware and the lights and wire it up yourself, all it is, is pos and neg.... ground it out somewhere and then run the pos from the foglights to a switch in the car and then on the other side of the switch continue the wire to the fuse box in the car and get whats called a fuse tap and that should do it for you.
and with this set up use that "foglight switch" to turn them on and off
also you'll be able to have your fog lights on when your highbeam is on
Old May 21, 2005 | 06:54 AM
thanx....should i tap it to the fog light fuse in the hood?
Old May 21, 2005 | 08:17 AM
drivinmax
no. get a fuse tap from discount auto parts or auto zone they are cheap and then tap into the cig lighter fuse under the dash
Old May 24, 2005 | 07:33 AM
BLaKtOut's Avatar
hows that possible ihave a98 gxe and mine came prewired the wires were located behind the bumper lights i thought all of them were the same i guess not now
Old May 24, 2005 | 08:26 AM
OneToughMax's Avatar
don't just run the positive wires from the fogs to a switch then tap the fusebox. the fogs are going to draw way too much power. you have to use relays to draw power directly off the battery, then run the switch inside. do a google search for foglight wiring. there are tons of write-ups on it.
Old May 24, 2005 | 11:12 AM
JPMax's Avatar
What's next!?..
I think I read on a dealer's website somewhere (courtesy?) that all maxima's come prewired for the oem foglights. The plugs are just taped up behind the bumper somewhere.
Haven't personally checked it though.
EDIT: Here's the actual page from courtesyparts.com
http://www.courtesyparts.com/Merchan...de=999F1-A3279
Old May 24, 2005 | 11:15 AM
i put oem fogs in my 97 gxe and the harness was there. i just plugged the fogs into it, put in the fog relay, changed the blinker stalk... donedeal.com
Old May 24, 2005 | 03:37 PM
Went to the site and it says "1997 to 1999 maximas are pre-wired for fog lights (except SE and GXE A/T models without factory ABS, VSS, and a Drivers Power Seat)."
Therefore, my car isn't pre-wired. Looks like i will have to wire them to my own switch. Ill just wire it straight to the battery with a relay.
Old May 26, 2005 | 09:13 AM
BLaKtOut's Avatar
i have a 98 gxe a/t model how can i verify of the abs because i had the wires
Old May 30, 2005 | 09:20 PM
aapp81's Avatar
Are you saying that you're not sure if you have ABS even though you have wiring for it? Or do you mean you have wiring for the fogs?
Either way:
I don't have ABS either but judging from the cars I've had in the past along w/ other ppl's cars, when the key is in the RUN position and your cluster lights up, there should be an ABS light... right?
Someone w/ ABS please correct me if I'm wrong.
...or just slam on your brakes and see what happens...
Matt93SE
May 24, 2019 02:58 PM
Finkle
Sep 27, 2015 09:53 PM
Viralkill
Aug 17, 2015 10:54 AM
Viralkill
Aug 16, 2015 05:09 PM
MikesChevelle
Aug 6, 2015 11:36 AM
