CEL-evap vent control valve??
Old May 22, 2005 | 11:43 AM
zx2max's Avatar
check engine light is on giving code for evap vent control valve. Is this something that is fixable or do i just buy another one?
Old May 23, 2005 | 10:39 AM
zx2max's Avatar
also, could this cause my car to having starting problems?
Old May 23, 2005 | 01:03 PM
maxxximum90's Avatar
i had the same code.
i bought the evap canister control valve and the evap charcoal canister...its easier to replace both at the same time. from what i remember it was like 70 bucks total for both parts. takes like 20 mins to do
raise the driver rear wheel up its behind it. all u need to do is remove some clamps for hoses and a few bolts...
Old May 23, 2005 | 01:35 PM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Canistor Contorl valve is 95.50 at every nissan dealer ship I called. I Just replaced mine, The code said, Evap Canistor valve contorl Stays Open under diffrrent driving condition.
Old May 23, 2005 | 02:25 PM
Maxgig's Avatar
I had that same issue with my 97 SE. I was getting the same codes, 0705 and 0214. My mechanic changed the purge solenoid and the vacuum cut valve for $217. After 3 days the CEL lit up again with the 0705 code again. I got pissed and told him to keep the car until he fixed it, he eventually had to change the evap vent control valve which cost $123. But he gave it to me free for all my trouble. It seems that the OBD II system runs in a continuos loop setup and anywhere along that loop if something fails you have to check each part til you find the right one thats broke.
Old May 23, 2005 | 02:38 PM
tomservo291's Avatar
What code, there are a bunch of EVAP codes that all basically say the same thing... but there's two different locations of parts of the EVAP system (some behind rear driverside wheel and some right by the throttle body.)
Just replaced all my hoses in the engine bay dealing with EVAP hoping it was an air leak. Codes haven't come back on yet, been a week so far... knock on wood.
Old May 23, 2005 | 04:50 PM
zx2max's Avatar
Is it necessary to get the evap charcoal canister too or can i just replace the canister control valve?
Old May 23, 2005 | 05:06 PM
i guess sometimes the control valve is stuck onto the canister...so rather than pry it off and break it....i just replaced both...
over time the canister gets filled with fuel anyway...so why not replace it
gavin68
Sep 18, 2021 12:36 PM
Miket2006
Mar 1, 2021 03:55 AM
tseng1023
Oct 15, 2015 08:30 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
