shortening the shifter
Old May 22, 2005 | 11:45 AM
Zyzzyan's Avatar
whos got their shifter cut down?
You know, taping down the stck, then sawing it down.
Testimonials?
Ive done it on a few cars, works fine, but their was one car that it made shifting too hard, Im curious if the Max maybe included into this group.
:::EDIT:::
Here is this site to do it properly.
http://www.icbm.org/erkson/personal/...shortening.htm
Here is the ORG site about how it feels
http://forums.maxima.org/showthread.php?t=334732
Old May 22, 2005 | 12:01 PM
mendon99's Avatar
tastey wheat
bump im curious also. id like to do this
Old May 22, 2005 | 01:03 PM
mendon99's Avatar
tastey wheat
Zyzzyan i guess some people have done it. heres a thread cus no one else helped us out:
Old May 22, 2005 | 01:10 PM
Zyzzyan's Avatar
alright. that gives me my testimonials *goes out to garage*
Old May 22, 2005 | 01:24 PM
dawalkster's Avatar
is craving Bojangles
ive done it, cut it off just below the threads. as far as impressions- i didnt cut it enough, the throw didnt change at all its just for asthetic purposes but it does look better. just make sure you have a **** to put on afterwards cause your stocker wont work. oh and its a good idea to put a plastic bag over the shaft while your cutting or else shavings will go everywhere
Old May 22, 2005 | 01:28 PM
Zyzzyan's Avatar
No I am taping it down, I can use the stock ****.
Old May 22, 2005 | 01:32 PM
Zyzzyan's Avatar
*dones flame suit*
From my fellow Dubbers
Old May 22, 2005 | 02:26 PM
mendon99's Avatar
tastey wheat
just tried it with my dremel. had an old aftermarket **** laying around... looks good, nice and easy you just have to take your time or you'll keep braking wheels.. i took about an inch off, should have done more too, maybe 1.5" to 2"..
Old May 22, 2005 | 02:38 PM
madnut's Avatar
Isnt it better to replace with a short shifter instead, dont you get a lil more lever that way?
Old May 22, 2005 | 02:51 PM
ManualMaxima's Avatar
5th Gen till she dies!
i have a choped down STS, and once choped down it made it alittle more knotchy. If you have the stock shifter you will notice alittle change but it will not be to bad. When i had my stock in i chopped it down about inch and a half and i loved it. i just got a saw went out in the car and put a sheet down so shavings would not go everywhere and went at it. i dremels those 2 pieces that stick out off, and put on a aftermarket ****.
Old May 22, 2005 | 06:46 PM
rome06's Avatar
i cut my stock one down low as fu*k and it worked pretty good....it was like at the same height as the flip down tray right under the head unit....then i just got a sts...but it drove and felt fine
Old May 22, 2005 | 06:50 PM
Lumberg™'s Avatar
on this site too damn much
where can you get one of them thread cutters and how much so you can still use your stock ****? and how do aftermarket ***** fit anyways? dont they have threads like factory? i know my aftermarket ichiban **** in my accord had threads so it screwed on.
Old May 22, 2005 | 06:56 PM
Zyzzyan's Avatar
It is a Tap & Die Set. They are about 100 bux or so, every mechanic can use one, they are great for customizing things.
Old May 22, 2005 | 08:19 PM
killerVQ30DE's Avatar
Some aftermarket shift ***** use 3 allen key screws around the outside of the ****, these usually bite into a rubber sleave you put on the shifter to hold it tight and stop it turning on you when you shift.
Old May 22, 2005 | 08:24 PM
tomservo291's Avatar
Yea and generally speaking they suck (from my experience.) If you do use an aftermarket **** that has set screws make sure you get it done right the first time and don't need to take it apart many times (like I did) from tightening those set screws enough times it actually STRIPPED THE THREAD ON THE SHIFT **** ... so I had to do some customization to make my MOMO **** stay put after that...
Old May 22, 2005 | 08:49 PM
Flava_24/7's Avatar
Boosted Panda
I also cut my STS down....
Cutting the stock down is purely cosmetic.It will not shorten the throw just by lowering it.
If after you cut it, and if it feels notchy install some syn. trans fluid and you will be surprised how good it will feel. You should do it anyways. The Maxima tranny isnt the smoothest of trannies.
Fbana41
Aug 29, 2016 12:18 PM
lux97Max
Sep 28, 2015 11:18 PM
atriuum
Sep 28, 2015 01:19 PM
ef9
Sep 10, 2015 10:35 PM
