Brake Pad Shims Missing!
Old May 22, 2005 | 12:10 PM
DR-Max's Avatar
Just replaced the front pads. I discovered that the old pads had shims rivetted to the worn pads. The new pads I bought, from Autozone, didn't come with shims. Because I was running out of daylight last nite and I don't have any other means to go back to Autozone to get shims, I went ahead and put the new pads in. I did put this red liquid anti-squeek on the pads before installing them.
Driving with the new pads this morning, my brakes make a little bit of noise when I apply the brakes. It also makes kinda like a mild grinding sound, but not the same sound as a badly worn down pad would make against the brake rotor. Still its annoying.
I have never bought brake shims alone before, I don't even know if they sell them separately. What alternatives would you all suggest?
Thanks.
Old May 22, 2005 | 01:22 PM
afroken's Avatar
sure u got the right pads? mine came with shims
Old May 22, 2005 | 01:27 PM
dawalkster's Avatar
is craving Bojangles
shims wont make to much of a difference. unless you really want to have shims you could go back to autozone and pick up some new pads but otherwise id just put the ones you have now on. just make sure you put on some anti-squeak and youll be fine.
Old May 22, 2005 | 02:01 PM
DR-Max's Avatar
The pads fit, so I'm assuming its the right one. I did put that anti-squeek stuff and it still squeeks.
Old May 22, 2005 | 02:09 PM
nadir_s's Avatar
vicodin ... gift of life
umm ...
the anti-squeel is supposed to go on the back of the brake pads and under the shims ... sorta like a glue.
Old May 22, 2005 | 02:26 PM
DR-Max's Avatar
I know nadir but the shims where missing from the old pads. The old pads came with shims rivetted onto the back of the pads. The guy must have thrown away the factory shims.
I think i know what I'm gonna do, go back to Autozone and try to get my shims.
Old May 22, 2005 | 02:29 PM
madnut's Avatar
I forgot to put the shims back before, felt no difference shim no shim
Old May 22, 2005 | 05:01 PM
MaxGordon7's Avatar
i dont have any shims, brakes pads do take a while before the settle in nicely
Old May 23, 2005 | 12:46 AM
DR-Max's Avatar
I'll give a few days then. The pedal feels nice and stiff but stopping takes a bit of an effort right now. Somehow it doesn't grab like before. I do have a faint grinding noise but looking from the rotors, I didn't see any grooves that could have been caused by that.
Old May 23, 2005 | 03:18 AM
ronin22357's Avatar
i dont have any shims on my current setup. you can get them though:
front brake hardware kit from nissan comes with shims #41080-00021 for '95, #41080-00022 for 96-99
jmlee44
Oct 2, 2022 02:13 PM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
