Brake experts help!
Brake experts help!
This picture is of the driverside front brake caliper. It looks to me like there is a pin-like thing sticking out (not a brake expert) do I need to worry? Is this something I can fix myself? Thanks in advance.
http://www.xanga.com/home.aspx?user=skyl1ne
please just go to that and click the A4/Max picture and you will see it.
I cannot host images but I need help!
The only thing is it protrudes a bit farther on the front driverside than anywhere else. The "pin" is on all the calipers, just furthest out on that one. I'm just wondering if this thing is going to slide all the way out. . . .More opinions please! Thanks for the feedback.
Originally Posted by joeeey
If I understand you correctly that it the wear sensor. When the pad reaches a point that metal plate touches the rotor and makes a squeaking sound to alert you that the pads are low.
You installed it backward, nothing to worry about. The pad that has the sensor should be on the back of the rotor, so it is not showen. It will still work tho.
Or you have put the both pads that have the sensor on one caliper, and the other caliper does not have any sensor.
That's right. It should be on the inboard side, because the inboard pads wears faster.
My woman's minivan had both inboard pads installed on the right side by car-x or midas or one of those dumbass shops. Flippin idiot, gosh!
I HATE those shops.. They're certified hacks.
04-16-2020 05:15 AM
HerpDerp1919
09-29-2015 02:02 PM
