what tires does everyone run on stock wheels??
Old May 15, 2001 | 06:21 AM
MaxSE98's Avatar
im lookin for a set of tires for the summer that offer the best of everything but are decently priced. most of all i want them to excel in handling circumstances , when it comes to launching ill just play with the clutch, im loooking at 225/50 zr16's anyone have suggestions??? thanks a bunch
max98se
Old May 15, 2001 | 07:34 AM
gtr_rider's Avatar
192.168.1.1
im not running stock for my car, but there stock maxima rims. Im running 225/50HR16 and they are great. Toyo Proxy FZR I think.
Old May 15, 2001 | 08:03 AM
mzmtg's Avatar
Minister of Silly Walks
I have the 15" rims. I've really liked the Bridgestone Potenza RE930's that I've had. I just ordered a set of the new RE950's so we'll see how those work out.
Old May 15, 2001 | 08:06 AM
Vinipux's Avatar
stock 15"
if you have a stock se which is 115/60/15 then you can run 225/60/15
I called up the tirerack.com and the guy said that would be no problem
enjoy
Old May 15, 2001 | 08:20 AM
SMX's Avatar
SMX
I have 99 SE rims and I'm running Nitto 450 225/16/50 so far so good!
Old May 15, 2001 | 08:27 AM
justmax's Avatar
stock 16" SE rims
with 225/50/16 bridgestone Potenza RE730's. They were $87 each on Tire Rack, and they perform 150% better than the stock 215/55/16 Toyos that came on the car.
Old May 15, 2001 | 10:04 AM
carl97ss's Avatar
on stock 16" rims, i'm running bf goodrich g-force kdws in 225-55x16. great tire. even thou the spec say it has a slightly larger diameter than the factory 215-55x16, i still runn 73 mph at 3000 rpms in 5th gear!
Old May 15, 2001 | 10:15 AM
s1rch's Avatar
bridgestone re730 on 225-50 16
nice look, nice grip !
Old May 15, 2001 | 10:19 AM
carl97ss's Avatar
do you find the 730's to be quiet at hyway speeds?
Old May 15, 2001 | 10:33 AM
GTRBlkMax97's Avatar
I have had the pepboys Futura Super Sport GTX 225/50/HR 16 I liked them alot but I burned them up realy quick. I just put some of the Kumho ECSTA Supra 712 215/55/ZR16s on my car and all I can say is DAMN!!!!!. I pulled out of my neighborhood when it was raining, and floored it, no wheel spin then punched it into 2nd gear and it spun very little. Tracktion is great and handling is wonderful! I got them from tirerack for $75 a piece good deal for the tires got them put on lifetime balance and an alignment for $146.00 at sears
A couple of my friends have them one with a 1997 Maxima, MaxedOut97SE, and one has them on a 1998 Contour SVT. They both love the tires I would highly recomend these tires
Old May 15, 2001 | 11:28 AM
Stillnmax's Avatar
Dunlop sp 5000 225 50 16's stock SE rims
Old May 15, 2001 | 01:18 PM
AndyXXL's Avatar
Dunlop sp 5000 225 55 16's stock SE rims
Old May 15, 2001 | 08:29 PM
02BBQ's Avatar
yokahoma avid H-4's; good hold
Old May 16, 2001 | 04:38 AM
LucentAUTO's Avatar
toyo
Old May 16, 2001 | 05:34 AM
Hercules's Avatar
While we are at the topic, if I put in 225/60R15 at the place of my current 215/60R15 tires, would that make the speedometer reading inaccurate? Or is the difference small enough to be ignored?
Old May 16, 2001 | 05:45 AM
DFWmax's Avatar
im running 225/55/16 dunlop sp sport 8000. they are good overall -- quiet, sticky, good in wet weather.
you have two choices for the tire size -- 225/50/16 or 225/55/16. i went with the 225/55/16 -- by the time i wear out the tread, i will be at the normal, unworn size of the 215/55/16 (original spec). if you go with the 225/50/16, you begin at the size of a worn out 215/55/16.
dfwmax
Old May 16, 2001 | 08:57 AM
maxnewbie's Avatar
I am running Bridgestone Turanza Revos H-Rated (215/60). They are super! Best tires I have ever owned. A little pricey though ($102.00 each). But well worth it. Rated at 80,000 miles.
Old May 16, 2001 | 09:36 AM
punabuds's Avatar
Pacemark 215/60/R15...H rated, pretty decent tires.
Old May 16, 2001 | 12:13 PM
derdoles
dunlop D60
Old May 16, 2001 | 10:19 PM
BobMax's Avatar
1.8% too low
See: http://www.miata.net/garage/tirecalc.html
So when your speedo says "60", you're really going more like 61mph. The efect on your gear ratio is more important.
Bob
Old May 16, 2001 | 11:03 PM
NYCe MaXiMa's Avatar
mine aren't stock but.. same size...
I'm on Sumitomo HTR 4 High performance
Old May 17, 2001 | 07:17 AM
Mishmosh's Avatar
Dunlop D60 A2 on my stock 95 SE 15" rims.
They are b*tt cheap, are great on dry pavement, OK in rain, but downright suck in snow. Luckily I have snows. In any case, noticeably better than stock toyo's
Old May 17, 2001 | 07:33 AM
GTNUKE's Avatar
I just put on a set of Michelin Pilot XGT H4 225/50-16. I've driven in dry conditions and heavy rain. So far, I love them. They're a little pricey, $126 at tirerack, but they are really great tires. I really would have liked the Pilot XGT V or Z rated, but those are even more expensive.
Old May 17, 2001 | 12:15 PM
Gary95's Avatar
Yokohama
I have Yokohama Y388's on 15" rims. They were $425 for all 4, which included all the other fees and taxes. H rated. Before that I had General Tire P2000's. The General's were a slightly harder ride for a little better performance than the original Toyo's. The Yokohama's perform just about as well with a noticeably softer ride. Because I drive the car alot, I prefer the improved ride. Thumbs up for the Y388's, so far (about 2k miles on them). They're great all season tires and grip nicely in the rain.
Btw, the stock for '95 was P215. I went for P225 to "fill out" the wheel wells better. Don't know what size the '98s have, but you may be able to do a similar size adjustment. Definitely recommend it, unless you're gonna try for a lower profile tire.
Old May 18, 2001 | 11:37 AM
drewm's Avatar
Bridgestone Potenza RE730s 225/50/R16
Best tires wet and dry that money can buy....
I'm never running anything else.
But then again.. I just went for an autocross ride around a parking lot yesterday in a stock IS300 with Bridgestone Pole Position S02's and DAAAAAAYMN. This guy was damn good too, controlled understeer to oversteer. Almost makes me wish I had a rear wheel drive.
homeyclaus
Sep 3, 2015 06:15 PM
sonic7
Aug 20, 2015 12:23 PM
MaximaDrvr
Aug 19, 2015 08:20 PM
twotonezed
Aug 16, 2015 11:41 AM
