Clutch Stuck to the Floor
Old May 22, 2005 | 09:23 PM
MaximusAureleas's Avatar
Leaving the grocery store today, I pushed in the clutch to start the car, released it, but it was stuck to the floor. There is maybe a half inch of play to the floor, and I cant engage any gear when the car is turned on (with the engine off, it slides into gear as if it was normally depressed). When I push the clutch completely in while the car is on, i'm getting something that sounds like a bad power steering pump kinda sound. The car is stuck in a parking lot tonight until i get it towed out of there. Never had any signs leading up to this. Just wondering whats going on if anyone would have an idea...
Old May 22, 2005 | 09:27 PM
killerVQ30DE's Avatar
Check your clutch fluid, most likely your master or slave cylinder has died
Old May 22, 2005 | 09:36 PM
Mr.Duck's Avatar
yea, did you check your clutch fluid? and mike where you been man? how come you dont come out to the meets no more
Old May 22, 2005 | 09:53 PM
I havent been around the .org much lately, i've been overly occupied with work and personal stuff. Ill make it to a meet one day. Im looking towards upgrading to a WRX or a 2k2 6spd (if i can ever find one) sometime over the summer.
Old May 22, 2005 | 09:57 PM
clutch fluid should be full, ive never noticed a single leak from the car. Ill check to be sure in the AM. Assuming it is, the master/slave cylinder would be the culprit then? How labor intensive is the replacement?
Old May 22, 2005 | 11:26 PM
garbury's Avatar
I had this problem when replacing my clutch in my 3rd gen VE. I don't know if this applies to the 4th gen but I'll try and help out anyway.
The rod attached to the throwout bearing is attached to a ball on the transmission (all of you who have done clutch jobs should know what I'm talking about). It is attached by two metal clips that wrap around the ball and rotates on that ball. For me, we didn't put the metal clips in well enough and when I pushed the clutch in it went all the way to the floor. Check out the boot on the transmission where the throw out bearing is and push on that metal throwout bearing bracket. It should unstick the clutch, but if you depress the clutch pedal again it will go to the floor. You need to remove the boot and place those metal clips back in place and that should fix your problem.
Old May 23, 2005 | 06:35 AM
joecraps's Avatar
This happend to my Max at a stop light! My clutch master clyinder had deveolped a crack on the outlet side and the fliud had drained out. You might try taking a couple of bottles of DOT 3 and topping it off while pumping the clutch pedal. You will have to grab the pedal and lift it of the floor - do this several times making sure you keep the fluid level topped off.
You can bleed it too if you have a buddy to continue the pumping while you release air from the top bleed port.
This may be enough save you the tow so you can drive it the repair shop if the master cylinder isn't totally fried.
Old May 23, 2005 | 09:46 AM
RedlineVQ's Avatar
it might not actually be dead, I had the same problem and bled the clutch and just end up doing it every three months when it gets weak. And after i bleed it, it feels like new.
tarun900
19
Dec 20, 2021 06:57 PM
05RLS2
Apr 14, 2016 11:49 AM
RealityCheck
Oct 2, 2015 06:34 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
zmcneely13
Sep 26, 2015 02:26 PM
