Warpspeed questions
Old May 23, 2005 | 01:51 AM
TurboMax67
Warpspeed questions
My new car has a warspeed y-pipe, hi-flow cat, b-pipe, and magnaflow muffler. When I go WOT through a few gears and come to a stop, I smell a strong sulfur type smell. Is this normal? Maybe I have a problem? After the car settles the smell dissapates. Also, how do I tell if I have the 2.25 system or the 3'' system? It looks very big, but I dunno o_O. Thanks~~
Old May 23, 2005 | 01:55 AM
ewuzh's Avatar
Your cat probably died.
Old May 23, 2005 | 02:13 AM
JOMAN's Avatar
mayb clutch?...or could be ur cat breakin in....
Old May 23, 2005 | 02:22 AM
maximazation's Avatar
well it is a high flow cat...the fumes might smell somewhat different.
Old May 23, 2005 | 08:59 AM
SPiG's Avatar
SomePsychoGuy
A tape Measure.
You want a 2.5" inner diameter exhaust unless you are SC or Turbo. If you are not then consider a new name.
It is probably your cat if you have a sulfur smell. Take it off and see if the cleaner is still in one piece. If not then talk to warpspeed about it and see if your car has a problem to ruin a cat.
Brakes and clutch also have smells if either is working pretty hard. It is a very different smell though.
Old May 23, 2005 | 12:41 PM
86maxima96's Avatar
I Broke OT
i also had a strange sulfur-like smell when i installed my budget y. it went away after about 25 or so miles on it. almost like it had to break in? not sure. but fine now!
Old May 23, 2005 | 01:23 PM
NCSU_MAX's Avatar
Maximoneypit
i think the smell your getting is just the new pipes being "broken in" (unless your cat is bad as mentioned above) ive been through 2 WSP Y-pipes and have their B-pipe and experienced the same thing the first few days. should go away soon if thats what it is.
Old May 30, 2005 | 03:35 AM
Pronto's Avatar
Catalytic converters don't work until they are hot. Your probably not getting it up to temperature before going to WOT so the extra raw fuel is'nt being converted. Try waiting until you have driven several miles and the engine is up to temp and the see what happens.
Unclejunebug
Apr 2, 2016 05:42 AM
Socalstillen
Sep 26, 2015 12:01 PM
