Wiper Fluid Not Working Wtf!!!!!!!!!!!!!!!
whenever i pull the handle for the wiper fluid nothing comes out the wipers turn on but thats it and the bottle is full of fluid
what could be the case is there some kind of fuse for the wiper fluid motor??????
I had something similar happen to me.. but with just one side. It ended up that I had to check all of the hoses and the exiting nozzle to remove any foreign object that could be blocking your system. I would check the fuses first and then if that checks out ok, disconnect the main hose that runs under your hood liner to a 2-way splitter and then try the wipers again. If water comes rushing out of the tubes then you know something is block your system down stream of that point. Good luck!
jerrod99_se-l
Aug 27, 2015 08:27 PM
