Transmisson rebuid, what parts do i need?
Old May 23, 2005 | 10:26 PM
madnut's Avatar
I am having the famous whining noise from my transmission so I decided I should rebuild it. I was wondering if anyone knows which parts I should swap in a rebuild.
Thnaks
Old May 24, 2005 | 05:56 AM
Chickan's Avatar
make sure you properly shim it, and there is a guide in the stickies.
Old May 24, 2005 | 12:29 PM
madnut's Avatar
thanks, i have seen the guide, but the guy that made it did not make a spesific list of parts to replace thats why i am asking
Old May 24, 2005 | 01:12 PM
adithius's Avatar
Are you sure you want to do this? I mean I think if your asking what you should change, you probably shouldnt be messing with the tranny anyway.
Old May 24, 2005 | 01:46 PM
i30ds's Avatar
Armed and Dangerous
Well this is a very subjective matter. Because of the noise, you should replace both bearings on the input and main shafts. I would also replace the differential side bearings as well. That is 6 bearings total. However, you could get in there and discover a bad syncro or two or maybe even a gear that needs to be replaced. You really wont know until you crack the tranaxle open.
Old May 24, 2005 | 05:35 PM
madnut's Avatar
adithius: as you can see from i30ds post its really hard to know what might be in need of replacement before you crack the tranny open so i am asking around so that I have the obvious parts when i open it up, from there its a matter of luck. Just minimizing the amount of time ill have no car. At any rate if i cant fixit ill just buy a new tranny.
i30ds: Thank you for your input
Mar 12, 2020 12:06 AM
t6378tp
Sep 29, 2018 04:27 PM
SpeedCrazie
Sep 16, 2016 03:41 PM
Lowered_a33
Sep 10, 2015 09:41 PM
videomano
Sep 8, 2015 03:28 PM
