My Tranny leaked all the oil out !!!
Old May 24, 2005 | 08:07 AM
Abimax95's Avatar
Hi there guys I had to replace my clutch disk and when I pull the tranny down I notice that it was dry as a bone where could it have leaked the oil I replace the two axle rings ..where else do I need to check I will post a picture of my clutch disk is pretty amazing that I drove it the way it was with out hurting anything else !!!!
Old May 24, 2005 | 09:10 AM
I30tMikeD's Avatar
You do know that there is no gear oil where the clutch is don't you? The gear oil is on the other side of the tranny where the gears are.
Old May 24, 2005 | 09:15 AM
CystumMax's Avatar
Well I should wrap this up before I start to ramble.
Now Imagine if there was oil where the Cluth is? What do you think will happen?
renatonetmail
isnt it drain the tranny part of the steps for a clutch change?
Old May 24, 2005 | 09:27 AM
MaximaSE96's Avatar
Maxima Owner
not if u can handle the weight of a tranny full of fluid.....
Old May 24, 2005 | 09:50 AM
I30tMikeD's Avatar
If there was no gear oil at all in a tranny, you could not be driving the car at all.
Old May 24, 2005 | 09:55 AM
Abimax95's Avatar
Tranny
Hi guys I know that the oil is inside the tranny ..but what I emant to say is that there was some oil splater in the inside case where the clutch is I will get some pictures today and post them tomorrow and you will see what i mean...th eclutch was install about 1yr half ago ...my question is ..is there a seal inside the case where the clutch is that I should look at before I replace the clutch ..I know it was leaking it but not much ..that's until I had to replace it ..the tranny was dry !!!!any clutch suggestions as in brands !!!!
spencerwh1
Jun 30, 2016 05:44 AM
foodmanry
Sep 24, 2015 12:02 PM
JoshG
51
Sep 21, 2015 10:41 PM
RWCreative
Sep 21, 2015 11:01 AM
ag90fox
Sep 9, 2015 12:22 PM
