New struts blew out in less than a week
Old May 24, 2005 | 12:13 PM
99NJMAX's Avatar
I just installed my illuminas not even a week ago and they've already blown! I'm running the illuminas on eibachs. Only the rear blew out and they've been set to 4, the front are at 2. Has this happened to anyone else? How could they have blown ins uch a short period of time? Any thoughts
Old May 24, 2005 | 12:17 PM
NmexMAX's Avatar
dot dot dot ...
How do you know they're "blown"?
Old May 24, 2005 | 12:25 PM
99NJMAX's Avatar
i heard a noise coming from my rear and i thought i forgot to tighten the scissor jack. i was leaning on the trunk and got off and it was bouncing. I pushed the rear down again and it just sprung up and down for a bit.
Old May 24, 2005 | 12:27 PM
NmexMAX's Avatar
dot dot dot ...
Did you buy them used? I wouldn't think so but ....
Old May 24, 2005 | 12:42 PM
JPMax's Avatar
What's next!?..
Take the wheel off and visually check the strut. See if there's any fluid on the outside that looks like oil.
Old May 24, 2005 | 02:42 PM
86maxima96's Avatar
I Broke OT
ahhh! i hate all of these horror stories!!
Old May 24, 2005 | 02:47 PM
sk24iam's Avatar
Now I'm reconsidering on buying these struts for my car.
Old May 24, 2005 | 03:44 PM
MrDicks95SE's Avatar
Offset Is Everything.
maybe because it was running on such a high setting that it blew out. usually when you buy new parts, even coilovers, you run it in the middle setting for about a week or two for it to properly settle in. then you can go ahead and adjust the hell out of it.
Old May 24, 2005 | 03:46 PM
86maxima96's Avatar
I Broke OT
so i shouldn't be scared of getting these if i install and break them in properly?
Old May 24, 2005 | 03:58 PM
why should you be scared? these are great aftermarket shocks that have been tried and tested over a long period of time. im running on a set and im very happy with them.
Old May 24, 2005 | 04:10 PM
Maxtank's Avatar
Guys, just becasue one guy blew a rear strut doesn't mean you shouldent buy them.
Old May 24, 2005 | 04:18 PM
86maxima96's Avatar
I Broke OT
r they still available at performance peddler? r they in stock? too late to call
Old May 24, 2005 | 04:25 PM
Stealth Max's Avatar
Tokico Illumina and KYB AGX are good stuffs if used properly. If your car is dropped too low then most shock and strut will not handle it. Just be careful or you will void the warranty. Like others have mentioned you need to let it break in first.
Old May 24, 2005 | 04:35 PM
Jatan's Avatar
Check and see if the spring is seated properly or not
Old May 24, 2005 | 07:17 PM
99NJMAX's Avatar
I think its my fault. I know eibachs have been known to blow tokicos. I was stupid and set them to 4 instead of something liek 2 or 3. Driving through these great northern nj roads didnt help any either.
No I actually just bought the last pair of the rears just before they closed. sorry. They're sending me those then I'll send them the blown ones and RMA them. When the process is done they credit me for the second pair of struts.
Old May 24, 2005 | 07:37 PM
Puppetmaster's Avatar
How do ya know that Eibachs have been known to blow Tokicos? I don't think that has anything to do with it. My Illuminas have 3500 miles on em and have gone through Eibachs, H&Rs, and Progress springs, but they're fine. Like someone else said, check em for leaks, check the spring seating, hardware, everything.... it may be something else.
Miket2006
Mar 1, 2021 03:55 AM
maxima-junky
Oct 7, 2015 06:13 PM
Need help
23
Oct 2, 2015 08:56 AM
Andy29
Sep 29, 2015 05:32 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
