Needle Removle
Old May 24, 2005 | 03:40 PM
JetBlackMax83's Avatar
Needle Removle
I know there is a write up in the stickies ive read it a couple of times because i was looking to mybe buy some red indiglo needles from the group deal for 71 bucks but i was just wondering how many people had the guts to actually take um off and how hard it it ive heard horror storys about breaking the gauges and i deff want to avoid this at all cost
Old May 24, 2005 | 06:45 PM
zboy's Avatar
I tried to be gentle with mine, and I didnt break anything...it was a little nerve racking at first but not nearly as hard as I thought it might be. They aren't perfectly lined up anymore but they're not off by much (e.g. my speedometer is off by about 2 mph).
There should be directions to follow online..out of the 2 styles of needles, we have the kind that you need to very gently pull up on as you twist them backwards (at least my 96 did). If you just try and pop them off you'll break your guages for sure.
Old May 24, 2005 | 06:52 PM
mendon99's Avatar
tastey wheat
lol...removle..sorry im a stickler for spelling. Removal**.
Don't remove the needles, 99.9% of everyone who has done this has messed them up, and its practically impossible to get them lined up perfectly again.. just clear them and put a different color LED behind them, and be done with it. just a suggestion.
Old May 24, 2005 | 06:54 PM
tommyali
ya deff dont take them off
Old May 24, 2005 | 06:56 PM
sunten1
Whoa you can clear them out w/o removing the needles...how...or is it in the stickies..???
Old May 24, 2005 | 06:59 PM
Metal Maxima's Avatar
SHIFT_om nom nom nom
You know that there is a calibration mode for doing this, right?
The only problem that I have seen people run into is messing up the servo internals when removing the needles.
Old May 24, 2005 | 07:00 PM
Step 9: Now is where **** gets crazy. You will need to strip the blue backing of the faceplate in order to make the light really shine through. In order to do this we will have to remove the faceplate (*duh*). START BY CALIBRATING THE NEEDLES. THIS MUST BE DONE!!!! To calibrate, do the following:
(i) Place your key in the ignition and hold in the odometer button.
(ii) Turn the electrical system on while holding the button in.
(iii) Release the button and wait one second.
(iv) Press the button three times. On the third press, HOLD THE BUTTON IN. If the digital readout reads '8' across the board, you are in luck. Otherwise, remove the key and repeat STEPS 9i - 9iii.
(v) You are now in calibration mode. Record where the needles lie. You can hold the button in for as long as you wish to take measurements.
Old May 24, 2005 | 07:05 PM
mendon99's Avatar
tastey wheat
yes, i've done it. i believe i found it in the stickies, yes again.
James92SE
142
Jan 2, 2024 09:23 AM
captchaos
Mar 15, 2016 12:18 PM
Rage Maximus
Sep 3, 2015 12:26 PM
Justinmc760
Aug 23, 2015 03:10 AM
egali045
Aug 5, 2015 09:02 AM
