intake manifold removal
Old May 24, 2005 | 08:23 PM
jedinyte120's Avatar
anyone have pics or a tutorial on how to remove the intake manifold? i need to replace my knock sensor.thanks
if you have a tutorial please send it to rogroc325@yahoo.com
roger
Old May 24, 2005 | 09:01 PM
dayglo's Avatar
you can do it without taking off your IM, and i personaly would leave it on just to save mess and hassle [gaskets?]. i would rather a couple sore knuckles
Motorvate.ca
this is a populare site with Maxima DIY's and hes got a good write up on how to replace your KS leaving the IM on. gooood luck, post results! i need to change mine out too just havent gotten the part yet
also, how much did you pay for your new KS?
Old May 25, 2005 | 06:00 AM
lilaclucymaxima's Avatar
Team Ramrod
Pick up a hanyes manual... it will help you out a lot not only with that, but in the future. I have removed my intake manifold before to clean it all out... it's pretty much common sense.
Old May 25, 2005 | 06:35 AM
KS was 79 bucks. i tried not to remove the manifold and it is a biotch.
i read the write up but its too tight under the manifold. can i spray wd40 on the bolt to help loosen it? will it damage anything around the knock sensor?thanks
roger
Old May 25, 2005 | 06:43 AM
tavarish's Avatar
fwd gone rwd cr00
if your car's not cali spec, it's not that hard at all...you may want to try reaching your left hand in there instead of your right, you'll find that you have a lot more space. you do have to break the bolt loose, and that requires some force. get the socket onto the bolt, and give it hell. it should come out pretty easily. I did mine for the first time in a matter of 25 minutes.
Old May 25, 2005 | 08:09 AM
dayglo's Avatar
a tiny trick but not realy, try putting a short socket onto the bolt first and then push the ratchet on, if its realy too tight. that might help a small bit. its helped a couple times for me
also where'd you buy your KS? anyone know where to get one cheap, i dont want to find a good looking deal and then buy garbage! thx
Old May 25, 2005 | 08:22 AM
THT's Avatar
THT
Throbbing member
IM removal is easy with a Haynes manual. Just read it, look at everything that's attached to the IM, disconnect, and remove.
Old May 25, 2005 | 04:10 PM
bought my KS from pinnacle nissan from their website.
James92SE
142
Jan 2, 2024 09:23 AM
bumpypickle
Sep 20, 2015 08:22 AM
bumpypickle
Sep 19, 2015 01:07 AM
Mahmuth
Sep 17, 2015 11:45 AM
