AE VLSD Transmission Question.
Old May 25, 2005 | 09:30 AM
iansw's Avatar
What is the difference in the 4th Gen Canadian VLSD and the 2001 AE VLSD transmissions?
Will the AE bolt right up to a 4th Gen?
Is the AE somehow better?
Are they the same, but the AE is just preferred because it is newer??
Old May 25, 2005 | 10:01 AM
1FSTMAX's Avatar
From what I understand, the 5th gen tranny has all the issues and bugs worked out that the 4th gen trannys had. Also they have slightly stronger components due to higher power output of the DE-K engine. The trans will bolt up to the 4th gen, but you'll need to use the LSD axles. As far as the Canadian 4th gen vlsd, and AE, I’m thinking it's the same trans, but the AE one would have all the bugs worked out as well as using stronger internals.
Old May 25, 2005 | 01:20 PM
i30ds's Avatar
Armed and Dangerous
[QUOTE=1FSTMAX]... As far as the Canadian 4th gen vlsd, and AE, I’m thinking it's the same trans...QUOTE]
the 4th gen canadian max vlsd is the same as the 96-99 US I30 vsld... isnt it?
Old May 25, 2005 | 01:23 PM
drivinmax
yup they are both the same
user 11122324
42
Jul 18, 2022 03:35 PM
doctorpullit
Mar 29, 2016 11:08 AM
Pied
Sep 26, 2015 03:29 PM
