2001 AE LSD trans into 4th gen
Old May 26, 2005 | 02:54 PM
Nealoc187's Avatar
SLOW
Any issues I should know about. Passenger side drive axle needs to be changed I know. Anything else that people have run into as far as problems with this swap?
Old May 26, 2005 | 02:56 PM
|Bijan|'s Avatar
UCF Lexus
Id like to know too.......
Old May 26, 2005 | 02:59 PM
1FSTMAX's Avatar
i believe the only other issue would be with the shift rods.
Old May 26, 2005 | 03:22 PM
THT's Avatar
THT
Throbbing member
IIRC, the shifter sits further back. Otherwise, it shouldn't be any different.
Old May 26, 2005 | 03:27 PM
|Bijan|'s Avatar
UCF Lexus
Using 4th gen shift rods - ?
Old May 26, 2005 | 04:12 PM
Nealoc187's Avatar
SLOW
Yep there's that issue too. I've got a B&M short shifter that sits way forward, so hopefully the issues will cancel eachother out. Any others?
Old May 26, 2005 | 04:57 PM
I30tMikeD's Avatar
Didn't Bejay1 do this swap?
Terran's Avatar
It does. Mine sits perfectly with a 2k tranny and a B&M.
Some have had to use the 4th gen speed sensor. My 2k works fine, but the 4th gen would have been fine too.
Old May 26, 2005 | 05:29 PM
Nealoc187's Avatar
SLOW
I think bejay had an I30t lsd not 2001 but I could be wrong. Thanks terran.
Old May 26, 2005 | 05:31 PM
I30tMikeD's Avatar
No, I know for a fact that he has a 5th gen 5spd. He got it done at the same shop that did my rebuild. Being LSD I am not sure about.
juani's Avatar
Rockin' VK56!!
I actually have 01 non-LSD tranny on my car, and everything's fine with it, no actually problem with it. with STS you'll be ok with the shifter position.
Old May 26, 2005 | 05:41 PM
BEJAY1's Avatar
Conecarver
The Stillen STS worked fine with the '01 AE tranny in mine. If the position did move it was so little I never noticed. Only change I needed was the driverside axleshaft as the inner gear size is diff from the A32. I see on carparts those things are still rare to locate if you need one. Over 20Kmi on mine and still gripping strong. Good luck!
Old May 26, 2005 | 06:23 PM
nismology's Avatar
Sorry to jack this thread but i have a 5th gen 5-speed in my car and was wondering if a STS from a 5th gen car will fit in mine.
Old May 26, 2005 | 06:24 PM
Terran's Avatar
The B&M is for 95-01. So as long as you mean the first half of the 5th gens then yes it will work fine.
MAXSE5SPD
Sep 17, 2022 04:00 AM
jfl330
Sep 4, 2015 01:44 PM
mikebla
Sep 3, 2015 05:37 PM
Lowered_a33
Sep 1, 2015 07:49 PM
