Lowest shot of NOS?
Old May 16, 2001 | 07:50 AM
NmexMAX's Avatar
dot dot dot ...
What's the lowest shot of NOS available? I think a 40 shot would be my choice, nothing more though. I read a post a little while ago and someone said a 40 shot was minimal. Where would I purchase it, and how much would it cost? Would a secondary fuel pump be necassary, and retuned ECU? What's the best way to go for a low shot of NOS, fogger, or injected? What kind of gains should I see? Thnx guys.
Old May 16, 2001 | 08:07 AM
RKS's Avatar
RKS
JC Whitney Kit
40-60 shot dry kit on sale for under $400 delivered. running a 40 shot probably won't require any other gauges or upgrades if the motor is in good shape.
http://www.jcwhitney.com/item.jhtml?ITEMID=49791
Old May 16, 2001 | 08:36 AM
NmexMAX's Avatar
dot dot dot ...
That's a dry kit, so my stock fuel system will be adequate, *BUT*, I want to be safe and not blow anything, so would it be possible to run a secondary fuel pump to only the N20 and not my injectors? Because if my stock fuel system has the slightest smallest blip or something, there goes the VQ. So when I hit the arming switch, I would also arm the secondary fuel pump so when the N20 is running, I won't ruin anything. Sound good?
Old May 16, 2001 | 08:38 AM
wicked1044's Avatar
what jet size does the kit come with??
are there any discount codes out there for jcwhitney???
Old May 16, 2001 | 08:40 AM
Sprint's Avatar
click the link and find out..
the lowest shot is SNEAKY PETE .. little 10oz bottle.. takes .1 secs off yoru 1/4 mile time.. i think it last for like 2 secs
Old May 16, 2001 | 09:02 AM
sx7r's Avatar
you could go lower than a 40 shot if you wanted. just use smaller jets.
25 shot = .024
30 shot = .026
35 shot = .028
i tried a 30 shot once, and i could BARELY tell if it was on or not. the only way to be sure if it was hitting, was if i saw my fuel pressure bumped up.
Old May 16, 2001 | 09:50 AM
RKS's Avatar
RKS
the kit does come with a fuel pressure safety switch that should shut off the n2o if fuel pressure is inadequate. you may want to get verification on this. i am looking at starting at a 50 shot and working up to at least 70 but i will be adding a better fuel pump and an assortment of gauges.
Old May 16, 2001 | 10:36 AM
NmexMAX's Avatar
dot dot dot ...
Wow, that's really good to know, maybe I'll got with the 50 shot also, Thnx a lot!!!
Maxboy23
55
May 1, 2025 06:09 PM
James92SE
142
Jan 2, 2024 09:23 AM
Apr 16, 2020 05:15 AM
brichi
Sep 15, 2015 07:20 AM
