Rattles!!!
Old May 27, 2005 | 05:40 PM
bhmax16's Avatar
Rattles!!!
Ok so I read the stickies, there is a how to on how to eliminate center console rattles, but that's not the source of any rattling I'm getting in my max. I found a few threads, and one guy said that the light fixture in his glovebox was causing lots of rattling, so I'm going to check on that tomorrow morning. I'm also going to take off my door panels and see if anything is floating around inside those.
Aside from that a lot of my rattling seems to be coming from the A-pillars though. Is there a way to remove the trim from the pillar and possibly reattach it? Or if not would adding a front strut bar help eliminate quite a few rattles or would I not notice much of a difference? Any advice is appreciated, thanks!
Old May 27, 2005 | 06:04 PM
DAVE Sz's Avatar
Hooooooonda.....
If it's coming from the pillar area, it's the pillar hitting the dash. Rip out the pillar, be careful not to crack it, and put some anti-squeak/rattle tape either on it or where the dash meets the pillar. Pop pillar back in.
Old May 27, 2005 | 06:40 PM
bhmax16's Avatar
Thanks Dave any special steps I should take while taking out the pillar? Do I just pop it out with a flathead screwdriver or is there more to it than that?
Old May 27, 2005 | 06:58 PM
DAVE Sz's Avatar
Hooooooonda.....
The wider the tool to pry it off the better. Make sure it's not too thin though. Peel back the rubber stripping along the pillar and stick the tool in there, pry it out.
Old May 27, 2005 | 07:23 PM
Maxtank's Avatar
the glovebox light...not sure how they sucured it, but mine fell out, and not it glows behind the radio...
My rear deck has some rattle sometimes also
Old May 27, 2005 | 08:10 PM
bhmax16's Avatar
Thanks a lot I'll give it a shot and see if I get rid of the rattles tomorrow
Old May 27, 2005 | 09:31 PM
ManualMaxima's Avatar
5th Gen till she dies!
these cars are horriable with rattles.....my sunroof metal peice broke and it is in my headliner rattling around it is annoying as ****....
Old May 27, 2005 | 09:50 PM
DAVE Sz's Avatar
Hooooooonda.....
mine did too manualmax.
Old May 27, 2005 | 09:52 PM
did you fix yours or just leave it. i have been just punching the roof and it will quit rattling for acouple min. i think i am going to pull the headliner down tomarrow and see what i can do.
Old May 27, 2005 | 09:56 PM
Loe max's Avatar
No need to remove the pillar trim, just stuff some soft object inbetween the gap to prevent the pillar trim from rubbing.
The only thing that rattles on my car is spoiler resonance over big bumps.
DAVE Sz's Avatar
Hooooooonda.....
The problem is that my slide panel for the moonroof fell off the track, actually one side broke off so it can't sit on the track right. Whenever I try to open or close the slide panel it's hard cause it goes in crooked. One day I got pissed and just jammed that thing backwards. Next thing I know the metal piece broke off. I just left it there. It's not making noise really, only when I close the door. I'll just rip it off or something. Still have the spare assembly in the junk car.
Old May 27, 2005 | 11:33 PM
bhmax16's Avatar
Thanks Loe Max, I'll try that first and if things aren't solved maybe I'll remove it then. By the way I'm the guy you hosted the Borla clips for and it looks like you still have them hosted so if I'm taking up too much space please feel free to delete them! You've had them up for me long enough (by the way thanks again!)
Wow guys sounds like that sunroof thing is a b__ch! Goodluck with that, thankfully my rattles aren't being caused by that. They're all definitely coming from the pillars and the 2 front doors. Any other areas I should check which tend to be common sources of rattles in our cars? My mom's '97 Avalon with 160k on it has less rattles than my '97 Max with 100k...it sux!
Old May 27, 2005 | 11:37 PM
DAVE Sz's Avatar
Hooooooonda.....
Trust me, peeling back the trim takes 2 seconds and makes it much, much easier.
Old May 28, 2005 | 07:38 AM
nismology's Avatar
The passenger side air bag cover can be a source of noises too. Mine is...
Old May 28, 2005 | 07:51 AM
jackiss2888's Avatar
ahaha, tooo funny
user 11122324
42
Jul 18, 2022 03:35 PM
lrb6805
Sep 17, 2015 04:49 PM
jerrod99_se-l
Sep 16, 2015 02:39 AM
thenewguyy
Sep 12, 2015 11:12 AM
NissanNismoZ
Sep 12, 2015 07:30 AM
