eibach and tokicos or eibachs and konis ???
Old May 16, 2001 | 09:45 AM
MaxSE98's Avatar
whats everyone got ???? im doing this upgrade soon so i kinda need to know what i should do , two maxima owners i know have just done springs , and i dont like the idea so lemme know , thanks again peeps
-maxse98
Old May 16, 2001 | 10:15 AM
dsmercado's Avatar
I have Eibach and Tokicos...
Pros: improved handling and cornering, reduced fender gap
Cons: harsher than stock ride
Hope this helps and good luck!
Old May 16, 2001 | 10:31 AM
Jose's Avatar
My opinion to your question->
I had eibach with tokico and they felt great when I first put them on, But eventually they started to get bouncy and rough. So I decided to get the konis like everyone else and in MY OPINION they ride a little to rough for my taste. Maybe I have to adjust them better for my taste but right now I am not to happy with my Koni purchase. I will suggest that you find someone with the set up that you are thinking of purchasing and go on a test drive. Everyone has a different opinion on how a car should feel and drive take your time because after your purchase you would be stuck with it.
Later:Jose
-maxse98
Old May 17, 2001 | 08:09 PM
RayD8MAX's Avatar
Eibachs & Tokicos are a good combination. You'll get use to the ride.
Old May 17, 2001 | 08:24 PM
Screaminfast's Avatar
hey jose....how much did you pay to have your konis put in the stock housing? or did you do it yourself?
Old May 18, 2001 | 11:32 AM
drewm's Avatar
Don't get Tokico's with Eibachs!!!! They will wear completely out in 10k miles. Spend the extra $150 and go for the konis. They won't wear out on you.
And for Jose, you might want to actually set you Konis stiffer, probably to around the middle setting. I've noticed at the lowest setting, the springs tend to bounce around a little bit giving you the harsh ride.
Old May 18, 2001 | 04:42 PM
Jose's Avatar
I had my maintenace department at my job cut the strut and drill the hole->
for me. Me and my friend did the install,If you have the right tools you shouldn't have much of a problem. It took us a couple of hours.
Later:Jose
Old May 18, 2001 | 04:47 PM
Jose's Avatar
I have the setting in the middle right now->
I guess living in the land of pothole (NYC) and having 18"rims don't help either. Maybe I am getting to old for this (lol)
Later:Jose
imported_Nismo_max
Feb 17, 2016 03:39 AM
Peter Paul
Jan 2, 2016 05:18 PM
MaxLvr21
Oct 17, 2015 12:11 PM
Stagnet04
Oct 11, 2015 08:16 PM
