rear brake write-up
A rear brake tool is a special tool used for most rear disc brake systems. It allows you to push the caliper piston in. Since the rear caliper requires the use of turning the compressing the piston at the same time, therefore a special tool is required. When you go to Autozone just ask for the rear brake caliper tool. or something like that.
i wouldn't even bother with the needle nose pliers...way to hard!!!! the toolkit is available at autozone for 35 and they refund your money when u bring it back. it takes like 5 minutes to do the back brakes with the tool. IMO that little square thing is a waste...never tried it on my max, but on my suburban it didnt work too well...renting tool from autozone is definately your best bet. good luck
phil
phil
thanks guys, on a side note when i was doing the front brakes...my raybestos qs pads came with some type of sticky brake shims? i used them along with the old metal shims when i put the new brakes on? should i have used both???
did my rear brakes today. took a while to get the piston turned in with needle nose pliers..but i think i did ok overall. thanks for the info guys...now i have to try and replace the seized parking brake cable
Is there a big difference between stopping power with OEM and "cheaper" aftermarket pads? Thing is, I have all OEM in the rear and I don't know what I have in front. My stopping power does suck, doesn't feel like the pads actually grab. So you think by not having OEM pads in the front is hurting me? I'm not actually sure if I do though.
Cant say anything about performance pad, but stay away from pad that have unlimited lifetime warranties. Those pads have some much metal in them that they
destroy the rotors before they go bad. So instead of changing pads in the future, you change rotors.... DOH!
Huttig2009
Sep 25, 2015 03:31 PM
