Power steering problem
Lately I've been having problems turning the wheel at slow speeds (<5mph). It's very stiff, as if there is no power steering (hence why I assume it's a PS problem). This only happens when the car is cold, like after sitting in a parking lot for a few hours. For a while I've just been putting up with this, but the last couple times I've needed to pull out of a parallel parking spot it's been a bit difficult. I already flushed and refilled the PS fluid (using a turkey baster to remove old fluid, add new, repeat a few days later as said in the fluids forum) but that didn't solve the problem. It's not leaking fluid anywhere. I haven't gotten a chance to look at the belts, I'll try to do that sometime tomorrow (though they are less than a year old, maybe 8k miles on them so I doubt they are the problem).
If the belts are fine, I'd guess maybe the pump is going bad? Does anyone know if that's it or have any other ideas? I'd like to try to fix this soon, but don't really have much of a chance to take it to a shop for a while with my work schedule. Thanks.
power steering belt?
the haynes manual does not seem to make any reference to a power steering belt? from what i can tell the power steering pump uses the drivebelt, if the drivebelt were lose i would be having more problems then just steering?
doesn’t the tensioner keep the drivebelt tight?
sorry if i am way off, i know a little about my car but as you can tell not enough.
-aPeG
-aPeG
The power steering belt is separate from the drivebelt and is tensioned separately. The other accessories (alternator, water pump) are driven by the main drive belt, but they are unaffected because the power steering belt is separate and only runs from the crankshaft pulley to the pulley on the power steering pump.
Is the power steering belt the serpentine belt, or is that something completely different? The Haynes manual has no reference to a serpentine belt, but I have seen in referred to on this website.
Just in case anyone has the same problem, the belt was just loose. I tightened it to spec and everything's fine now.
Also, I was wrong on my last reply to rmurdoch, both belts are technically serpentine type belts, I've never really heard the term applied to one or the other specifically though. Also, the main drivebelt does not go around the water pump, it's the AC condenser.
lowpost99
Oct 26, 2025 06:53 PM
The Frye
Sep 2, 2021 11:03 AM
trungg86
Sep 4, 2015 04:58 AM
sdotcarter
Sep 2, 2015 09:53 PM
