syptoms of a bad coolant temp sensor, how to test?
Old May 29, 2005 | 04:35 PM
Vlasic's Avatar
RaWr!!! ('''_(o_O)_''')
what are the syptoms of a bad coolant temp sensor? how do you test if the sensor is bad?
Old May 29, 2005 | 05:17 PM
tuff1's Avatar
Mine made the check engine light come on. This was confirmed by a dealer diagnostic check.
Old May 29, 2005 | 05:23 PM
mansurxk's Avatar
your car might buck and shut off for no reason. it senses the temperature improperly and will shut the car down. get a Haynes manual, it shows you how to taste it, you do an electrical resistance check.
Old May 29, 2005 | 05:49 PM
joeeey's Avatar
Higher idle than normal, using alot of fuel, CEL on. Get a haynes manual it will give you the resistance value of the ECT cold and while heating up.
Old May 29, 2005 | 07:55 PM
Vlasic's Avatar
k, thanks guys.
Old May 29, 2005 | 10:35 PM
MaxGordon7's Avatar
ya i had mine go out and it was CEL, then today i saw a little green stuff are the sensor and thought i maybe put in too loose. Boy my mistake i ended up tighting it too much, broke it clean in half. Then i cut my finger right nice getting the screw part out. Another 25 bucks to a sensor, I could swear last time it was only like 8 bucks but oh well, this one i put in just good and if it leaks im sure it wont be much.
MR2 T'd
Jul 9, 2021 05:06 AM
mvm062
Nov 30, 2020 09:00 AM
Maxima30
Sep 7, 2015 06:13 PM
lux97Max
Sep 4, 2015 05:42 PM
DrVee
Sep 4, 2015 12:18 PM
