engine specs of 4th gen, se, gle, gxe
Old May 16, 2001 | 11:50 AM
axionman
Can someone post the engine specs of a 4th gen Max?
also are there any differences between se, gxe, gle?
thanks
Old May 16, 2001 | 02:03 PM
gakary54's Avatar
thanks
I'm not quite sure what specs you want, so here is what I know:
24-valve, dohc, 3.0-liter 60-degree V-6
190 hp@5600 rpm
205 lb-ft@4000 rpm
10.0:1 compression ratio
6600 rpm redline
And there is no difference between the engines of the GXE, SE, and GLE.
Old May 16, 2001 | 02:07 PM
NmexMAX's Avatar
dot dot dot ...
Engine Code: VQ30DE
Layout: V6 DOHC Chain Driven Camshafts
Displacement: 2988cc
Horsepower: 190hp @ 5600rpm
Torque: 205ft lbs @ 4000rpm
Bore: 3.66"
Stroke: 2.89"
Compression: 10:0:1( I think
SEFI
Old May 16, 2001 | 03:57 PM
Sonic's Avatar
The differences between the GXE, SE and GLE have nothing to do with the engine, they are exactly the same. The GXE comes with the lowest level of standard equipment and a soft suspension setup. The SE comes with a firmer suspension, some cosmetic differences like foglights and white colored dashboard and the 5 speed/automatic option. The GLE comes with almost all options standard, is auto only and also has a floaty suspension, but comes with a slghtly different suspension setup (rubber vs. urethane bushings) and a 'computer controlled engine mount' setup. The third gens had different engines between model levels.
stevesmax
Dec 17, 2020 11:57 AM
WeetoddA32
Aug 16, 2015 12:45 PM
Team STILLEN
Aug 10, 2015 04:29 PM
