Help- Swirl Control Value
Old May 30, 2005 | 01:53 PM
MPMoney$'s Avatar
I have a 1999 Nissan Maxima-- Cali emissons model
Does anyone know where the swirl control value is located?
I checked all through my Hayes manuel- but found nothing.
Anyone who can help would be great-- thx
Old May 30, 2005 | 01:59 PM
1FSTMAX's Avatar
don't you mean swirl control valve? if so look at the lower intake manifold, it's there.
Kevlo911's Avatar
Kevlo for President
Lower intake manifold.
Old May 30, 2005 | 11:30 PM
FormorAccordMan's Avatar
That POS is located in the right hand side of the lower intake manifold. You will see a hose conected to it. That thing only makes it harder for us to cahnge out the knock senser if need be.
Old May 31, 2005 | 03:56 AM
Zack342's Avatar
Being a cali spec owner myself it will be almost impossible to change the KS yourself but they do help....
http://www.nissannews.com/site_libra...ma/index.shtml
quote:
The Maxima engine also utilizes the Nissan Valve Timing Control System (NVTCS) variable valve timing and lift management. Electronically controlled sensors measure throttle position and engine speed to activate the variable intake valve timing mechanism to meet demands on the engine. The NVTCS system helps provide better performance at lower engine speeds, without sacrificing high speed power output or fuel economy.
Old May 31, 2005 | 05:18 AM
njmaxseltd's Avatar
Originally Posted by zack342
This system is not in the 4th generation Maxima engine.
Old May 31, 2005 | 06:10 AM
Zack342's Avatar
well i guess nissan mad a mistake in their review.... you should let them know
Old May 31, 2005 | 06:27 AM
mzmtg's Avatar
Minister of Silly Walks
It is a mistake. There is NO variable valve timing or lift system on the VQ30DE. The swirl control valve is there to promote complete combustion at lower revs to reduce emissions.
Old May 31, 2005 | 09:20 AM
Zack342's Avatar
Cool. whatever the reason it meakes chaning the knock sensor impossible without removing the IM.
You guys should let nissan know there is a problem with their press release/ archive.
Old May 31, 2005 | 09:33 AM
mzmtg's Avatar
You can go ahead and do it, mmkay?
Old May 31, 2005 | 09:41 AM
CUSEMAX's Avatar
it isnt impossible to change ks without removing manifold, i did it, but it was a HUGE PAIN
Old Jun 2, 2005 | 06:37 PM
MPMoney$'s Avatar
Does anyone have any pictures of a swirl control valve?
I'm having some trouble locating it--- thx
Old Jun 2, 2005 | 06:50 PM
jdmmax's Avatar
stand on driver side of engine bay.
locate the fuel pressure regulator.
look a little below and to the left of the fpr.
you will see a gold mushroom looking thing.
that is the swirl control valve.
Old Jun 7, 2005 | 06:29 PM
MPMoney$'s Avatar
Anyone know the part# for the swirl control valve?
The friggin people at my local Nissan are complete morons--
they have no clue what a swirl control valve even is.
I need some help ordering this part--- thx
tarun900
19
Dec 20, 2021 06:57 PM
tseng1023
Oct 15, 2015 08:30 AM
RealityCheck
Oct 2, 2015 06:34 PM
DC_Juggernaut
Sep 28, 2015 04:07 PM
