MEVI propper working order?
Old May 31, 2005 | 01:54 PM
maxlinegtr's Avatar
To all MEVI owners how many of u have it propperly working right? Do u have all the components working or for the most of u, zip tied?
Just curious of your position.
thanx Tay
Old May 31, 2005 | 02:20 PM
hacim105's Avatar
Mine is in proper working order.
Old May 31, 2005 | 02:24 PM
NmexMAX's Avatar
dot dot dot ...
Mine's also in proper working order.
Old May 31, 2005 | 02:59 PM
maxlinegtr's Avatar
I always run into people with either the Harlem Switch not working and in result they zip tie thier actuators, having the butterflies open.
Old May 31, 2005 | 03:07 PM
Y2KSESteve's Avatar
Same here. Mine didn't work when I installed it but I didnt have any RPM switch when it went on.
Old May 31, 2005 | 03:18 PM
laylow1988's Avatar
mines work fine can't wait for ecu to come back
Old May 31, 2005 | 04:40 PM
Curt's Avatar
Mevi
Hooked it up right, and it operates right.
Old May 31, 2005 | 04:57 PM
killerVQ30DE's Avatar
The mevi is only effective from 5100+ rpm, surely having it always open would have a detrimental effect, if it was meant to always be open they wouldn't have it switched at rpm in the first place.
Old May 31, 2005 | 07:55 PM
matty's Avatar
Thats really Ghetto....make it work right like its suppose to...its not that hard...use a Harlan and make sure you use a Relay from radio Shack
If you wanna know if its working properly, get on the highway with a medium....get next to it and open it up..the intake Tone with Change when the MEVI opens...or get a light on your dash like i did, so when the MEVI opens, the light clicks on
-matt
Old May 31, 2005 | 10:06 PM
I30tMikeD's Avatar
A zip tied open MEVI results in about a 25lbs loss of torque untill 5K rpms. Very dumb to run that way.
Old May 31, 2005 | 11:26 PM
Powerman5115's Avatar
I'm running mine with a Harlem switch, works fine.
Mooney
Old May 31, 2005 | 11:27 PM
chuckie311's Avatar
mine
works fine
maxprivate
Forced Induction
21
Jul 8, 2017 09:48 AM
tnewbs
Aug 28, 2015 10:15 AM
jerrod99_se-l
Aug 27, 2015 08:27 PM
kirkhilles
Aug 8, 2015 10:53 AM
kenc15
Aug 5, 2015 08:29 AM
