ceramic or semi?
ceramic or semi?
so i need to replace the front brake pads on the max, and i was trying to decide between ceramic and semi-metallic pads. i heard that ceramic dont make any brake dust so your rims dont get nasty. is this true? is there any other advantage to ceramic, opposed to semi? what should i get? brands?
Originally Posted by rmurdoch
I bought the Raybestos PGD540 recently for the rear. They are semi-metallic and leave no brake dust whatsoever. I was told that the ceramic pads have a tendency to squeal.
Here that's all you need.
http://www.buybrakes.com/store/HB421-622
http://www.buybrakes.com/store/HB268-665
Wow. Excellent prices for Hawks. I may have to stock up for my next replacment............
I don't use my brakes anyway so it doesn't make any difference to me what pads I've got. Has Hawk got you on commission or what, CystumMax? You post their website everyday, lol!
Yeh in canneda everyone likes to Raybestos. IMHO it sucks
dont get semi-metallic. very noisy and have a grinding noise to it when heated up. unfortunately im running on semi-metallic and its nasty but still brakes hard. funny thing is that i have a lot of pad left after a couple thousand miles already. but id rather go with ceramic.
Originally Posted by RicoSuave98
so are theses ceramic? does that price include shipping? and whats so great about hawk?
Hawk Performance HPS pads offer 20-40% more stopping power and higher resistance to brake fade than most original equipment or standard replacement pads. This makes them more responsive and durable than most standard original brakes and makes Hawk Performance HPS pads the first …and least expensive…way to increase the stopping power of cars and light trucks.
As standard brake pads wear, brake dust is released as the friction material wears in everyday braking. Hawk Performance HPS brake pads are formulated to run cleaner and release extremely low levels of dust in normal street driving.
Key Features and Benefits of Hawk Performance HPS Brake Pads:
High friction/torque hot or cold
Gentle on rotors
Very quiet, low noise
Improved braking over OE pads
Extended pad life
Brake pads are wear items and as such, should be inspected regularly and replaced as necessary. Pads should be replaced when approximately 1/8th inch of friction material remains on the steel backing plate.
NOTE:
Even though Hawk Performance burnishes its brake pads as a final step in the factory, all brake pads have to be bedded-in with the rotors (new or used) that they will be used against. Properly bedding-in new brake pads results in a transfer film being generated at the pad and rotor interface to maximize brake performance.
Hawk HP Plus - High Performance Street PLUS Race Worthy Brake Pads
NOTE: BRAKES ARE A SAFETY CRITICAL PART OF A MOTOR VEHICLE.
Brake components should be installed by a competent mechanic in a professional manner. Any incorrect installation of brake components can cause a major safety problem or an accident. If you are not a competent and qualified mechanic you should not attempt to install these products, but should take the vehicle to a vehicle dealer or competent automotive mechanic for their installation.
Disc brake pads and rotors are wear items and as such, should be inspected regularly and replaced as necessary. Read More.
Secure online ordering and FREE GROUND SHIPPING in the Continental U.S. on orders over $100.
