View Poll Results: Have you replaced your Rear Main Seal?
Yes
22
17.19%
No, and no leaks
50
39.06%
No, but i need to
35
27.34%
What's a Rear Main Seal?
21
16.41%
Voters: 128. You may not vote on this poll
Old Jun 2, 2005 | 10:20 AM
eturnl
Im trying to get ain idea of how many of you replaced your rear main seal because you were leaking oil... Trying to determine if this is a common issue.
Old Jun 2, 2005 | 10:23 AM
njmodi's Avatar
Do I get a tax break?
heh heh - more preparation!
I can't help you with this - but should be good info to know - subscribed.
Good luck btw. You are taking on a bunch of things... if you have that many leaks, did you consider just putting in a new VQ3X?
Old Jun 2, 2005 | 10:54 AM
eturnl
My VQ runns beautifully! even at 140k, i'd rather have mine than one than one with 80k not knowing how well it was maintained.
btw, im not 100% sure it its my RMS, apparently a mechanic told me it was actually my upper oil pan leaking down in that area (appearing to be my RMS) so im not sure yet...
Old Jun 2, 2005 | 11:06 AM
njmodi's Avatar
Good point.
Old Jun 2, 2005 | 12:10 PM
DR-Max's Avatar
I just did this on mine yesterday. Mine has been leaking for a couple of years and finally got worse to the point where it was soaking my clutch and making it slip badly. So I did that with the clutch change. The work isn't easy if you don't have a lift and air tools. My buddy and I took everything off and pulled the tranny out in less than an hour in his transmission shop. The rear main seal is inside.
The following are things you need to remove before you get to it:
1) remove air intake assembly
2) remove car battery
3) remove engine mount on the transmission
4) unplug electrical connections
5) disconnect slave cylinder
6) remove front wheels
7) disconnect lower control arm
8) disconnect tie rod
9) pull out both driverside and passenger side axles
10) remove all bolts holding the tranny to the engine and pull it out
11) remove clutch cover and clutch disc
12) remove flywheel and you will see the rear main seal retainer (see pic below)
You will need two things, the retainer "O" assembly and the dust seal (depicted by the red arrow). The dust seal on mine had cracks all over it, that's where the oil was seeping thru. The rubber "O" seal is still in good condition but I replaced it anyway since I'm already in there:
I figured that the estimated time on this if you choose to have a shop do it is around 2-3 hours. That's R & R time and that's if they take their time.
Good luck.
Old Jun 3, 2005 | 09:05 AM
95BLKMAX's Avatar
i changed mine along with the clutch. Knock off 2 birds with one stone.
maximavqpower97's Avatar
i paid for this to be done.AND BELIEVE ME NISSAN SAID WAS A PAIN IN THE ***!
Old Jun 3, 2005 | 01:28 PM
Jason R's Avatar
aka UNCDooD
I did mine with like ~170k miles on the car.
Old Jun 3, 2005 | 01:44 PM
JeEvE's Avatar
Mine was leaking just a little bit so when i changed my clutch I decided to change the seal. It ended up leaking a lot worse because I didnt not notice the retainer seal not being flush around the crank so it ended up getting ripped. I did it again and it seems to be leaking a little still. I am sure the retainer seal is perfectly around the crank but I think I screwed up with the dust seal. Is the dust seal a part I can buy from Nissan, because I filled it in with black RTV and gave it time to set. When I did the seal the second time it seemed like the RTV made a nice seal so the oil would not leak but its was hard to tell when it was already leaking from the retainer seal. If anyone can help me out with this, that would be great. Thanks.
Old Jun 3, 2005 | 02:26 PM
DR-Max's Avatar
Yes you can get the dust seal separately, they actually come separately (not included with seal retainer). I used a feeler gauge, the finest one, to check if I have a gap behind the retainer. The rule of thumb is to ensure that the retainer sits flush with the engine block. I also applied black RTV around the entire retainer to make a good seal with the crank, including the dust seal area. I let mine dry overnight before putting everything back together. Also when you get your new dust seal, put a thin coat of grease on the edge of it that has contact with the engine block. This will enable that thick seal to slide easily into place ensuring a proper seat. Also, we used a seal driver. It's a special tool that has a round end, which is the same diameter as the retainer "O". Then you can use a mallet and hit the other end of it, this will drive the retainer evenly towards the engine block. Do not hit the retainer directly with the hammer. That stuff is aluminum and can easily get damaged. Hope this helps.
Old Jun 3, 2005 | 02:36 PM
JeEvE's Avatar
That helps a lot, thanks DR-Max. I ended up making the entire Dust Seal with RTV. When you said you put RTV around the entire retainer to make a good seal with the crank, did you mean the brown round seal in which the crank spins in? Also, where can I find that special tool you used. I tried my best to put the seal on evenly and then i used a paper clip to make sure that the brown seal around the crank was flush.
Old Jun 3, 2005 | 04:53 PM
nismology's Avatar
[img]http://img86.echo.cx/img86/8651/rear-seal.gif[img]
Good luck.
Nice set of instruction there. But in my experience it's easier to just seperate the steering knuckle from the strut than disconnect the control arm. This is referring to #7.
Old Jun 3, 2005 | 05:35 PM
DR-Max's Avatar
The brown/redish "O" seal doesn't need the RTV. I put RTV around the retainer, the aluminum holder that actually bolts onto the block. I don't know where to get that tool, my buddy owns a transmission shop so he has all the cool gadgets. Maybe you can try Autozone, I'm not totally sure though.
Old Jul 10, 2005 | 03:22 AM
Product_Of_Korea's Avatar
does anyone have a site where i can pick up a rear main seal i tried searching the search engine and all i could come up with is one for the vq35de.can some one help me please
thanks
Old Jul 10, 2005 | 07:18 AM
JwaxMax99's Avatar
thanks
Better use a Nissan part, buy it here.
http://www.parts.com/partlocator/ind...99&catalogid=1
Old Jul 10, 2005 | 01:12 PM
Mishmosh's Avatar
JeEvE. It is perfectly fine to use RTV instead of the dust seal. Given proper curing time, it'll hold up just fine. What may also being going on is that oil is still leaking past the rear main seal and not around the dust seal area. That is what is happening to mine. I have no explanation for that except that there may be some free play of the crank. When I installed the seal, I tried moving around the crank end by hand and it wouldn't budge but going at several thousand RPM and especially with any imbalance, it certainly is possible for the crank end to rotate off center more than the RMS can seal up. I am wondering if my years of UDP use maybe contributed to that (I have since removed it). My car is also 10 years old now. In any case, the bottom of my bellhousing has wetness of oil and I seem to need to add a qt every 3000 miles. I am resigned to leave it be. The small leak does not appear to be compromising the clutch function at least.
Old Jul 11, 2005 | 04:55 PM
MaxKlinger's Avatar
Same here, 209,000 miles on mine and it doesn't leak a drop of anything (knocks on wood).
Old Jul 14, 2005 | 09:20 PM
JeEvE's Avatar
Im not sure what it is, oh well. I dont have to worry about it anymore since the engine is coming out. I hydrolocked it and the piston smacked the block, making a huge crack in it and all the oil leaked out.
Old Jul 14, 2005 | 10:13 PM
kingrukus's Avatar
no more maxima...
I wonder if this was the problem when my car was burning 1L of oil every 1000km. My local dealership couldn't find the leak...there was no visible sign nor was there any smoke to indicate such a huge loss in oil. They monitored the car for a while and couldn't determine the source of the probleml. As a result I got a new motor free under the ASP 160k km warrenty.
Old Sep 24, 2005 | 03:56 AM
Mishmosh's Avatar
If it was the rear main seal, they could tell if it is leaking rather easily. Between the transmission and motor mating surfaces, at the bottom, there is a drainage hole that will leak motor oil if the rear main seal leaks.
Old Sep 24, 2005 | 05:39 PM
DcMaN's Avatar
get a new engine... my 2 cents. vqs are cheap you can find them for about 350 $ . I got one for 350$ with 40k shipped. Ran great and still does even though my car got flipped over :X
Old Sep 27, 2005 | 02:46 PM
way2fast95's Avatar
once you get the tranny off, what are the rest of the steps to change the rear main seal and dust seal? And what exactly is RTV? my mechanic was suggesting just to clean the oil leak real good with brake cleaner and then use high heat sylicon to create a new external seal. Is this adaquate? How much more difficult is it to just replace the rear main seal and dust seal?
Thanks.
Old Sep 27, 2005 | 03:05 PM
Mishmosh's Avatar
If you are doing a clutch job, the only additional steps are to remove the flywheel, clean off the area, remove the old rear main seal/bracket/dust seal, clean of the surfaces, and replace. RTV is just the sealant. A reasonable extra charge would be 1-2 hours labor.
As for the "external seal" that your mechanic suggested, I think it is time to get a new mechanic.
Old Sep 27, 2005 | 03:13 PM
way2fast95's Avatar
We are going to change the clutch while were at it, however we were wondering about the rear main seal. What are the steps involved in removing the rear main seal and replacing it, the steps in this thread end with getting to it, but not removing it and replacing. Don't you have the drop the bottom of the block to access it?
The external seal he was talking about sound similar to what some of the members posted above saying they used RTV to seal it instead of actually replacing the dust seal.
Old Sep 27, 2005 | 08:00 PM
Mishmosh's Avatar
OK, my bad for dissing your mechanic. If the leak was the dust seal, then potentially you could just clean and RTV the area.
The rear main seal itself is just part of the bracket which is nudged out after the 3 bolts securing it are removed. You simply need to clean off old sealant, carefully mount the seal onto the crank after coating the edges with RTV. Getting the dust seal to sit right is one of the tricky parts. The other is making sure the rear main seal sits flush against the crank (use the end of a paper clip and go all the way around to check). Some have used RTV completely instead of the dust seal (allow sufficient time to cure before starting the car).
Old Sep 28, 2005 | 02:41 AM
Frank Fontaine's Avatar
wonder if "new" motor is like new starter or new caliper etc. i.e. remanuf. Doesn't make a lot of sense to do something like that. When my motor did that, it was the sending unit or whatever it's called.
Old Sep 28, 2005 | 07:56 AM
Yup, me too! I had no leaks, but I figured, hell, while I'm replacing the clutch, might as well do some preventive maintenance!
Old Oct 18, 2005 | 02:52 PM
mrnock's Avatar
I have this same issue. What would be the normal asking price for labor from a decent mechanic?
Old Mar 4, 2007 | 07:40 AM
CoamoMax's Avatar
Does anyone know the part # for the dust seal or does it come with the retainer and rear main seal. Thanks
Old Mar 4, 2007 | 01:44 PM
willard00's Avatar
i havnt. i need to though. but im not going to. cars not going to be my problem anymore in a couple months.
Old Mar 5, 2007 | 12:45 PM
LASTONE's Avatar
Yes replaced mine last week when I did the clutch. It was leaking bad enough to ruin the clutch. I have 137k on the car. It was not that hard but that was last week and now seems so far away haha.
Old Mar 5, 2007 | 05:35 PM
MadMaxSE-L's Avatar
Doggah Bite...
thant's my plan as well. I have the 5th gen clutch to go in, but I just can't kill this stock 4th gen clutch!
-Matt
Old Mar 5, 2007 | 08:04 PM
spn350z's Avatar
I replaced my at 140k along with clutch, master/slave cylinders, upper and lower clutch hose and drive shafts and changed tranny fluid.
I had to do the clutch but things started showing iffy, minor leak in rear main, leak or seapping (moist) fluid near the bandjo ends of both hoses and busted outer drive shaft boots with cracked dry inner boots.
Hopefully good for another 140k miles.
Old Mar 5, 2007 | 08:15 PM
moogotzskillz2's Avatar
i changed my rear main seal 2 times in a month...
Dont ask, first time i was planing on just changing the clutch then when i took my flywheel to get resurfaced i noticed a small leak so i was told since i'm down here replace it. so i buy it and put it in, I really didnt do any research on how RMS are put in and what u buy with it.. so i just changed it not knowing i needed a Oil pan seal..
Anyways, after the first day of putting everything back together and driving it, i see that my car is leakin like crzy. thats when i read and saw this seal that i never put, so i dropd my tranny last weekend, and now its runing like a champ
Old Mar 23, 2007 | 11:08 AM
KRRZ350's Avatar
yeah this old thread is garbage.... in the 2-years it's been around I'm sure alot of people had to re-do there rms. http://forums.maxima.org/showthread....&highlight=rmshttp://forums.maxima.org/showthread....&highlight=rms
jskirwin
Jun 8, 2016 08:49 AM
vingodine
45
May 21, 2016 12:46 PM
Huttig2009
Sep 25, 2015 03:31 PM
maxipower
Aug 21, 2015 11:10 AM
