yay more problems for me even with a new engine...
Well anyway i recently did a tune up on my car, ngk plats oil etc... Well now alot of the times it doesnt start. And if it does start the idle is sporadic it shakes the car violently and sometimes it doesnt. I checked the fuel injectors for a"clicking noise" and i hear it clicking. Does anyone know what the problem could be? If i give it gas it always starts up.
check all coil packs individually. With the car idling, unplug your coil packs (the connector) one at a time, and listen for a noticable/audible drop in your engine rpm. If your engine speed doesn't drop, then you've found the problem cylinder. Next try swapping out coil packs from another cylinder. check spark plug (make sure its not fouled). Test injector for correct ohm's (don't remember what it is off of the top of my head).
Hope this helps.
Hope this helps.
ok ITS NOT the coil packs ive taken them all from a friend whos coil packs work perfectly and they still make my car idle like ****. But anyway this is what happens it starts off good and then about 5 minues into the drive i come to a stop lite and my idle begins to drop. It then makes the car stutter and then catches it self and brings it back up.
the idle it self is fine plus i know how to do it. Its something else. Like the TPS or something. Because it usually drops to 500 rpm or lower and then it starts to shake and it catches it self back up to about 700
Originally Posted by DAVE Sz
you deserve everything that is happening to your car.
My boss did not say I deserved it, or the firm deserved it. He simply said I better learn and if it happens again I'm fired.
Long story short is that we're all gonna make mistakes in life--just learn from them.
Originally Posted by killcrap
sounds like a bad TPS/IACV/ vaccum leak.
checked that way ahead of you hehe. they both seem to be ok. i think ifigured it out though. I am almost certain it is a bad plug. Im praying thats what it is i cant afford for it to be anything else
Bad plugs as in, not gapped properly???? Like Dave Sz suggested, check the plug gaps. I have been buying plugs since I started driving my first car at 16 y/o. Everytime I install a set of plugs, I always check the gap even if it is specifically for your car. It's always a good practice to do so to eliminate little annoying problems like yours. Don't assume......as a matter of fact, never assume when it comes to automotive stuff. An improperly maintained vehicle is a dangerous thing on the road which could endanger lives! Didn't mean to get mellow-dramatic on ya.
actually is it safe to use another brand spark plug in the engine i need to drive around but i cant drive it the way it is till i replace the plug. I am going ot order the same plugs in my car now but i need to drive on something temporary would it be ok to mix and match or no ?
litch
123
01-04-2024 07:01 PM
jmlee44
10-02-2022 02:13 PM
HerpDerp1919
09-29-2015 02:02 PM
