18x7.5 with offset 48... will they fit?
Old Jun 3, 2005 | 03:58 AM
browne's Avatar
hey all, i just got some rims off ebay but they sent me the wrong rims. i ordered 17x7 with offset 40 but they sent me 18x7.5 with offset 48. does anyone know if these rims will fit my 98 maxima? thanks.
Old Jun 3, 2005 | 05:24 AM
ImmaSquashYou's Avatar
why don't you get up and stop being lazy and put them on!!!! they prob do'nt have tires, but you can still see if the rim is going to hit anything like the control arms, etc. etc. If you they do fit, and you have extra cash laying around, you lucked out in a way. but lemme tell you that tires are much more expensive for 18's than 17's. approx $60 more on each tire. so $60 x 4 is another $240 you woulda saved if you went with 17's instead of 18's
Old Jun 3, 2005 | 05:45 AM
browne's Avatar
dude, chill out... they sent me the wrong rims and i dont want to install them since i might i have to return them. just wanted to know if anyone has tried this combo with no problems. if they fit then ill just keep the rims and sell my current 17 rims/tires for some 18" tires.
Old Jun 3, 2005 | 06:03 AM
junaiddada's Avatar
Maximus
Yes!!! they will fit Easily.
Old Jun 3, 2005 | 07:11 AM
sorry, didn't mean to sound like i was bashing on you. sorry if you took it the wrong way. but it should fit without a problem. if not use spacers. but i'm pretty sure that they will fit...but you can still open one of the boxes and just put them on your car to check if it does fit correctly
Old Jun 3, 2005 | 07:32 AM
I30tMikeD's Avatar
They may fit but it will be close. But you really don't want a 48mm offset. Send them back.
Old Jun 3, 2005 | 08:12 AM
1FSTMAX's Avatar
i have 48mm offset wheels.. they fit fine.. no rubbing or anything..
Old Jun 3, 2005 | 08:39 AM
kormax97
I have 18x7.5 +45mm offset and it fit fine. only had little probablem with the center cap on the rear cause of the grease caps but i fixed that problem very easily.
Old Jun 3, 2005 | 01:03 PM
browne's Avatar
im also lowered with eibach pros/gr-2. will that make any difference? also, are you rolling on 235-40-18?
just want to make sure cause ebay seller is not responding... thanks
Old Jun 3, 2005 | 03:29 PM
Supermax95's Avatar
With a hammer and chizel?....= ]
Old Jun 3, 2005 | 03:50 PM
1FSTMAX's Avatar
or a 5mm spacer..
Old Jun 4, 2005 | 01:13 AM
browne's Avatar
anyone else use 48 offset. dont want to waste money on tires if there not going to fit? thanks
Old Jun 4, 2005 | 04:47 PM
browne's Avatar
bump.......
Old Jun 4, 2005 | 04:53 PM
kormax97
that's a no no.. that grease cap is there for a reason. never remove it.
or a 5mm spacer..
i tried with a 10mm spacer but still wasn't enough space!! and plus the lugs were barely staying on so i took them off and did this... take the nubs off the center cap and super glue it on to the rims it's been on past 2-3 months now and it's waaaay better than having no center cap
Old Jun 4, 2005 | 05:04 PM
browne's Avatar
are you having any problem rubbing?
Old Jun 4, 2005 | 05:05 PM
kormax97
nope never.. even on a hard bump or going mucho fast and turning... no probs
Old Jun 4, 2005 | 06:20 PM
liqidvenom's Avatar
brotherhood of tq
i have 18 x 7.5 r1's and i rub every once and a while... im not sure what offset my gtr-10 wheels are though
Old Jun 4, 2005 | 06:43 PM
browne's Avatar
are you rubbing your front fenders or the inside strut assembly?
aw11power
Oct 10, 2021 04:57 AM
Apr 16, 2020 05:15 AM
trsandrew
Apr 8, 2016 06:45 PM
trsandrew
Oct 25, 2015 02:47 PM
Pied
Sep 26, 2015 03:29 PM
