Do our brake pads have a warning when thin??
Old May 16, 2001 | 07:00 PM
KL99SEA's Avatar
My 99 SE makes a scraping / squeel sound when just first applied. Goes away after 1 second when applied harder. Do the pads have those metal tangs that warn when they are getting thin??? I have about 40K light to moderate driving on them? I do not have ABS.
Old May 16, 2001 | 07:05 PM
Sonic's Avatar
Sounds about right for replacing them.
Old May 16, 2001 | 07:35 PM
redmaxpa007's Avatar
i SeE what you did therE
mine are doing the same thing right now... i am ordering brake pads from phuong... aka gotrice tomorrow...
Old May 16, 2001 | 07:52 PM
Daniel B. Martin's Avatar
Yes. Here is a quote from the Owner's Manual.
Brake pad wear indicators
The disc brake pads on your vehicle have audible wear indicators. When a brake pad requires replacement, it will make a high pitched scraping or screeching sound when the vehicle is in motion whether or not the brake pedal is depressed. Have the brakes checked as soon as possible if the wear indicator sound is heard.
Front pads typically wear out sooner than rear pads, so check the fronts first. If the rotors are not conspicuously worn and you have not felt any pulsation in the brake pedal, you may need nothing more than new pads. Replacing worn brake pads is something which may be done by the home mechanic. You will find good coverage of this subject in the Haynes manual, pages 9-5 through 9-9. Doing the front pads is easier than the rears because the rear calipers have the complication of the hand brake mechanism.
Brake pads can wear out in 25K miles or 100K miles. It depends on your car (brakes wear faster with automatic transmission), your driving style, your driving environment. In a stop-and-go urban area brakes wear quickly. In 100% highway driving the brake pads never wear out because they are lightly used.
Old May 16, 2001 | 07:59 PM
KL99SEA's Avatar
Thanks for the info, I will probably get front rotors turned and pads. I can do it and just take rotors in to get done. Thanks again all of you.
litch
123
Jan 4, 2024 07:01 PM
Apr 16, 2020 05:15 AM
NmexMAX
May 23, 2016 07:38 PM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
