New knock sensor! but still has KS code.
Old Jun 3, 2005 | 07:53 PM
hdiggeddy's Avatar
I installed a brand new knock sensor? It felt great for a little bit like a week. Then the today it wasnt running great. I checked the code and it came up as the knock sensor. Could it be the harness? and how would i check it, if i pulled it back out?
Old Jun 3, 2005 | 07:54 PM
GodFather's Avatar
Made in Taiwan
you have to torque screw that thing correctly. can't be too loose or too tight.
Old Jun 3, 2005 | 07:57 PM
hdiggeddy's Avatar
what is the TQ on the bolt?
Old Jun 3, 2005 | 08:04 PM
GodFather's Avatar
Made in Taiwan
you are going to have to search for that, i am at the summer internship, so i cannot access the fsm like i'm at home. sorry.
Old Jun 3, 2005 | 08:08 PM
Ninos_Maxima's Avatar
be the change u want2C
alot say that the stock tq spec is too much, thats why it gets the crack on the side. What year is your maxima anyways?
Old Jun 3, 2005 | 08:10 PM
njmodi's Avatar
Do I get a tax break?
1. did you check the harness when you replaced the old KS
2. did you clean the grounds when you replaced the KS (behind the fuel rail near the plenum)
3. did you clean the KS harness connectors when you replaced the KS
Old Jun 3, 2005 | 08:15 PM
THT's Avatar
THT
Throbbing member
Check the grounds. That was the culprit when I first thought my KS was dead. It lasted another 15K before it actually kicked the bucket.
Old Jun 4, 2005 | 09:14 PM
sexytom976's Avatar
IF you drop it, it magically turns to crap... (shot)
Old Jun 5, 2005 | 12:09 PM
96ItaliaSE's Avatar
il massimi bassi
ok heres the deal if you had no check engine light but a computer stored ghost code for the knock sensor then you must replace you KS. If your CEL is illuminated for the knock sensor it is either unhooked or another component is triggering the KS most notably the air inlet temperature sensor my moms VQ infiniti had a issue just like this.
The check engine came on for the knock sensor and it was a faulty air inlet temperatire sensor telling the MAF the temperature outside was 5 billion degrees and the computer tried to adjust to this and went nutty.
I am assuming you reset the computer after you put in your KS...keep us updated
Old Jun 5, 2005 | 12:18 PM
mansurxk's Avatar
i think the torque on teh bolt is 15 ft-lb
Old Jun 5, 2005 | 12:19 PM
NewEngSurf's Avatar
im pretty sure i have a faulty knock sensor , but not all the time, im have inconsistant performance (remember im representin the 3ed gen (92 VE )) , how can i check the grounds? im kinda a newbie with this diagnostic stuff, ps. my check engien light isnt on
Old Jun 5, 2005 | 12:43 PM
AxisKill's Avatar
first i'd say try resseting the ECU and then see if you still have the code.
Personally i just installed a new KS a few days ago and i still have a CEL but i didn't check to see what the code was... my car is currently in a shop getting all sorts of brake stuff done.
Others have reported having O2 sensor issues that made the ECU give a faulty KS code. (i think im one of those people, but i won't know till i get my car back)
so basically
1. reset ECU
2. check for O2 sensor codes
if the above doesn't work then i suppose you may be right about getting the wrong TQ on the bolt.
the only writeup i recall is http://www.motorvate.ca/mvp.php/507 which says 15-20 feet per pound.
- good luck
Old Jun 5, 2005 | 03:30 PM
Rutnick's Avatar
could be the connection, torque of the KS or harness. When I bought my new KS, I got it with the harness from Courtesy Nissan.
Old Jun 5, 2005 | 05:22 PM
mendon99's Avatar
tastey wheat
my girl's max had the exact same problem, she took it back to the mechanic (i woulda done it myself, but it was under waruntee, she just bought the car, so free install), and he said the reason the ks code keeps coming up is because it basically thinks its a bad knock sensor, but in reality one of her O2 sensors was dead, and kept triggering it... he replaced the faulty one and no more CEL light
my03maxima
Jul 28, 2024 07:40 AM
DC_Juggernaut
Sep 28, 2015 04:07 PM
zmcneely13
Sep 26, 2015 02:26 PM
