Power Steering hoses
Old Jun 7, 2005 | 07:34 AM
JiggsHall's Avatar
Does anyone know what size (diameter) the hoses are for the Power Steering? I've had a leak for a while, I had someone turning the wheel while the car was running but I can't tell directly where it is coming from, and it's not leaking directly from the resourvoir. The fluid that leaked out is mostly on the frame under the radiator. I tried looking in the Haynes Manual but it didn't have the info I was looking for.
Old Jun 7, 2005 | 07:41 AM
Bobo's Avatar
Why do you care what diameter it is? Do you intend to fabricate your own? Why not just replace it in kind with OEM? It can't be very expensive.
Old Jun 7, 2005 | 07:45 AM
JiggsHall's Avatar
I haven't checked the price on the OEM. If I know the part number of the hose I would buy it. If anyone has the part number that would help.
Old Jun 7, 2005 | 07:49 AM
Bobo's Avatar
Phone the dealership and describe what you're after. They will have the part #.
Old Jun 7, 2005 | 07:53 AM
JiggsHall's Avatar
I'll check there and at Autozone.
Old Jun 7, 2005 | 08:05 AM
JiggsHall's Avatar
I actually just checked with a few Nissan dealers and a complete hose assembly is about $140 USD. I don't need the wholse assembly though.
Old Jun 7, 2005 | 08:08 AM
njmodi's Avatar
Do I get a tax break?
Look up the Midway Nissan thread in the group deals forum - post a message for Dan Tech - he'll take the time to hook you up with the hoses you need. If Nissan only packages things as an assembly - he won't be able to split that up for you - but he'll get you a much better price than your local dealer offered.
Old Jun 7, 2005 | 08:14 AM
JiggsHall's Avatar
Thanks njmodi, I'll post it .
Old Mar 18, 2006 | 09:20 PM
pjalst
I have the same problem with my 96 max. It looks lke there are two hoses that run from the Power steering fluid resivoir down near the radiator. I can't tell which one is leaking either.
Old Mar 19, 2006 | 06:14 PM
JiggsHall's Avatar
I'm still having the problem as well. I believe the part numbers are 9725MC and 9725MD. Is your Max a 5 speed or an auto ?
Old Mar 19, 2006 | 06:50 PM
PLUMMAXSE's Avatar
I just bought the oem low pressure hose for about $40 from Pinnacle Nissan. The High Pressure hose is much higher about $140 to be exact. They also have a seal kit which you might need if you replace the hoses. From what everyone says you want to use the nissan hoses, cause the other ones are cheap and will burst on you. This is not a cheap problem to fix. Buy a Sh8t load of ps fluid!!
Old Mar 20, 2006 | 07:13 AM
pjalst
My max is a 5 speed
Old Mar 20, 2006 | 07:38 AM
maxfanfromohio's Avatar
Shiver me timbers.
I have had this same problem with my wifes 98 auto for a couple of years now. I have just ignored it and purchased alot of ATF fluid to keep filling the resevoir. It only happens when it is cold outside. It's waaaaayyy past getting old at this point.
Old Mar 20, 2006 | 07:49 AM
pjalst
Are these parts also know as the Pressure Hose and the Suction Hose?
Old Mar 22, 2006 | 05:32 AM
pjalst
Can anyone answer this?please
Old Mar 22, 2006 | 11:17 AM
PLUMMAXSE's Avatar
What is your question???
Old Mar 22, 2006 | 01:07 PM
pjalst
My question is, are the two hoses that run from the Power steering resevoir down to the radiator known as the Pressure Hose and the Suction Hose?
Old Mar 22, 2006 | 02:45 PM
PLUMMAXSE's Avatar
You have a high pressure and a low pressure hose. The low pressure hose is the suction hose. It is connected to the bottom of the PS fluid tank and is fed by gravity. The high pressure hose is the long one that you see up near the firewall and left hood strut on the passenger side.
Old Mar 22, 2006 | 03:19 PM
pjalst
thank you much
lowpost99
Oct 26, 2025 06:53 PM
conansriver
Nov 18, 2015 02:46 PM
followthadollar
Sep 13, 2015 09:55 AM
SusieQQ
Sep 9, 2015 12:14 PM
