Parking lights fuse/relay?
Old Jun 7, 2005 | 12:01 PM
Chief Brody's Avatar
All of my parking lights suddenly went out-- side markers, clearence lights, and rear tails. The brake lights work as well as the headlights/signals/fogs. I took a look at some fuses and they looked good, but I didn't find one specific to this system. Is there a special fuse for the parking light (first click on the lights control) or a relay for it? Anyone have this problem before?
Any suggestions are appreciated.
Old Jun 7, 2005 | 12:03 PM
njmodi's Avatar
Do I get a tax break?
It could be the stalk/switch assembly has called it a day...
Old Jun 7, 2005 | 12:18 PM
I thought that too, but the lights on the instrument panel come on even though none of the parking lights are one. The other thing I noticed was that the little beep that comes on when you leave your lights on with the door opens doesn't come on anymore. Curious.
Old Jun 7, 2005 | 12:23 PM
njmodi's Avatar
Then we're back to the fuse theory... re-check all the fuses. The labelling may not be obvious - so just check them all. Be sure to check the fuses in the engine bay too.
Old Jun 7, 2005 | 12:32 PM
Sounds like a plan. I'll do that now.
Old Jun 7, 2005 | 12:45 PM
Ha, that didn't take too long. Fuse number 5 on the fuse box. Thanks so much for the help man.
Old Jun 7, 2005 | 12:47 PM
njmodi's Avatar
Old Jun 7, 2005 | 03:24 PM
alpimax99's Avatar
check all the fuse with an multimeter just ground the ground and go from there. i use a probe that connects to the battery using +/-. it tells you everything with the probe if the fuse is bad it will just some ground.
Old Dec 22, 2021 | 06:16 AM
mrwood's Avatar
I don't understand this last procedure from Alpimax99 describing how to use the multimeter to check fuses. Is a long lead from the multimeter to the battery needed? Could someone clarify? Thanks.
Old Dec 22, 2021 | 09:06 AM
KP11520's Avatar
I don't think English was his first language. Maybe not his second either!
If you have a DMM with continuity check as a feature, take out each fuse one at a time and put each probe on one of the two legs at the same time. You will get a light or a tone if it is good. Remember to touch the two probes together at first to make sure it is set right and works. Sometimes we can't see very small breaks/burns. No light or tone.... REPLACE.
Old Dec 23, 2021 | 11:03 AM
mrwood's Avatar
Thanks for the procedure. Something basic, but I didn't know how to do this.
sctludwig
Sep 1, 2022 01:32 PM
captchaos
Mar 15, 2016 12:18 PM
fastcarny
Oct 6, 2015 10:42 AM
markevans999
Sep 10, 2015 04:29 PM
Maxima30
Sep 7, 2015 06:13 PM
