Maxima weight....
Old Oct 10, 2000 | 04:09 AM
josh95se's Avatar
I have a 95se auto and checked on the drivers door pillar to see what the weight of the car is....the sticker says the gross vehicle weight is 1938kilos...or roughly 4270lbs!!! I know that this has gotta be wrong cause thats like as much as a Mercedes S class 4dr. I thought the 4th gen is about 3075lbs. Is this a misprint on my door or am I reading something wrong? (Or is the Canadian model made out of gold with a trunk lined with bricks?)
Old Oct 10, 2000 | 04:15 AM
ronskal
Gross weight is the maximum vehicle weight allowed.
The empty weight is 3000 to 3100 depending on options.
Old Oct 10, 2000 | 04:44 AM
josh95se's Avatar
Thanks....that makes more sense....
Now I know if I can carry 4 250lb friends around no problem....just imagine how sllloooowww you'de be then!
Old Oct 10, 2000 | 02:39 PM
Zprime's Avatar
my maxima and me
probably weighs about 3300
It has all the option minus heated seat and power pass
and I weigh about 220lb
ahahahahahahah
Old Oct 10, 2000 | 02:45 PM
Synki's Avatar
I always thought the car weighed around 3150-3250 or so. Maybe I'm wrong, correct me if I am. 4000 something lbs? We are talking pick-up truck weight! Either that or you have some very thick boned friends in your car!
Old Oct 10, 2000 | 06:34 PM
Micah95GLE's Avatar
The '97 GLE is rated at 3085lbs. The '97 SE manual is rated at 3014lbs. The '97 GXE manual is rated at 3012lbs. The '95s should be a little lighter, since they have less emissions equipment and crash safety stuff.
Old Oct 10, 2000 | 08:01 PM
Mike Cline's Avatar
Just looked at mine. It says 4273lbs.! Mine is a 95GLE. Wonder what 3lb. option mine has that yours doesn't?
Old Oct 11, 2000 | 06:35 AM
machavez702
That weight on the door is estimated with passengers. Your suppose to subtract like 180-200 lb for for each passenger that it will seat. 180 x 5=900 lb.
Old Oct 11, 2000 | 06:41 AM
JimW
instead of guessing-->
take your car to a local truck stop (near any major interstate) and weigh it on their scales. Or go to a local dragstrip and weigh it. Your estimates will be much different than your actual weight.
My 95 GXE with S/C package and aftermarket wheels(16's) RSB FSTB, Stillen Y, Popcharger and complete aftermarket stereo (no subs) weighed 3440 with me in it (I weigh 220)
I 95 Cali-spec 5 spd car with the same performance mods weighed 200lbs less than my car.
Most of the curb weights you see posted are empty weights.
Goffery2uned
Aug 21, 2015 09:50 PM
julian888
Aug 6, 2015 04:39 AM
julian888
Aug 5, 2015 08:26 PM
