A/C Recharge
Old Jun 11, 2005 | 12:18 PM
  #41
SMX95's Avatar
You must convert the system over to R-134a. Don't try to put in R-134a into a R-12 system. That's a no no. Your compressor will certainly not last longer than a week.
R-134a system is a whole new system, new compressor and lines.. ect.. My A/C is cold as hell and I mean cold. Solid ice baby. Go to target pick up a recharge kit with the gauge already on the unit itself. Inexpensive bottle, will fill up your A/c if it isnt that cold. It will also read the PSI of the low side line. Also will indicate a problem if there is one.
Old Jun 12, 2005 | 08:32 AM
  #42
davey6693's Avatar
Originally Posted by crux06
No cold air.Had to take my 99 Max to the shop today to have AC diagnosed.
Tech said compressor is shot leaking all over. Wants $800 to replace it. Is this a reasonable amount?
Sounds high to me. Find out what he's doing there. Compressor should be about 300, dryer 40, refrigerant 50 and labour about an hour at 75ish. I make that 465 as a rough guess.
Old Jun 12, 2005 | 02:00 PM
  #43
FishyMan's Avatar
i guess recharging a bit w/ r134a is good, but i guess if we had to COMPLETELY refill or charge a system, oil is needed.
even my manual suggests to use a specific oil, but it doesn't say for which application.
so basically anything with a guage then? or will it be better to buy a RETRO fit kit? and save the fittings just in case?
my system is cold and i dont think i have any leaks, even the technician above said, a system shoulnd't need charging unless a leak is present. so im not in a rush to try this out. but checkers has a retrofit kit on sale.
can someone confirm the r134a/oil thing? i would think a system that is cold, needs just a bit of r134a alone cans in it, while a system that has lost most of it needs the r134a/oil cans?
Old Jun 13, 2005 | 06:52 AM
  #44
crux06's Avatar
Shop wanted $500 for compressor, $50 for drier,$50 for refrigerant and $200 for labor. I told him NO THANKS!
Old Jun 13, 2005 | 07:12 AM
  #45
billy bronco's Avatar
What happens when you over charge your AC system ? Can that be done using the little cans from AZ. My compressor makes a whining noise above 2000 rpm, also seems compressor is no kicking in & out. It blows super cold air after I added a can. Seems to be too much pressure maybe ???? Can I just bleed some off?
Old Jun 13, 2005 | 08:02 AM
  #46
SMX95's Avatar
I have the same noise, its starting to go away, you did over fill it. best way to remove some pressure from the system is to put back on a container or
R-134a and let some of it go back into the bottle.
Old Jun 13, 2005 | 08:05 AM
  #47
SMX95's Avatar
I did have the a/c papers with me at some point. I got them from ALL DATA. It listed what PSI each line should be, What type of oil, How much freon to add in.. ect ect.. If I can get to the computer lab again ill print one out.
Old Jun 13, 2005 | 08:06 AM
  #48
I have no container, what if I just put on the gauge or push the little valve some?
Old Jun 13, 2005 | 08:10 AM
  #49
SMX95's Avatar
Its highly not recommended to do this but.... Wear gloves, Safety glasses, an air mask and a long sleeve shirt. Make sure you have water near you and a rag to clean up the oil/freon that might go all over the side of the engine. Be very careful.
BkGreen97
Apr 2, 2016 05:47 AM
mclasser
Sep 24, 2015 11:57 PM
homewrecker
Sep 24, 2015 07:01 PM
maxima297
Sep 24, 2015 01:18 PM
EdRomo86
Sep 12, 2015 07:49 PM
