Just had the 02 sensor replaced and code is still showing
Old Jun 8, 2005 | 12:52 PM
Umass021's Avatar
I replaced the 02 sensors and I still am getting the same code. I replaced both of the front ones. What eles can I do?
Old Jun 8, 2005 | 01:16 PM
Maximized Jiggs's Avatar
Are you sure the code wasnt for the rear one? Try resetting the ECU and keep driving.
Old Jun 8, 2005 | 07:26 PM
beefy23b/97's Avatar
Just keep driving the ECU will reset if you fixed the problem after so many starts....
Old Jun 8, 2005 | 08:46 PM
Jepht20's Avatar
Custom User Title...
also check the fuse for it while you're at it...i've heard others say that was blown.
Old Jun 8, 2005 | 08:58 PM
njmodi's Avatar
Do I get a tax break?
What code are you getting?
Old Jun 9, 2005 | 12:28 AM
Umass021's Avatar
First bank something. I will find out the number.
Old Jun 9, 2005 | 08:32 AM
Umass021's Avatar
I forget how to reset the codes again. Do I put the key in the on position and turn the screw on the ecu back and fourth once?
Old Jun 9, 2005 | 08:35 AM
maximavqpower97's Avatar
am having problem with a 02 sensor ,can u tell me what code was it ( 1001 ?
Old Jun 9, 2005 | 08:36 AM
njmodi's Avatar
Yes. It is in the stickies.
Old Jun 9, 2005 | 09:40 AM
JPMax's Avatar
What's next!?..
back and forth once to see the codes. back and forth again to reset.
Make sure you didn't put too much anti-seize grease on the threads when you put the new sensor in. Sometimes that will screw up the sensor.
Old Jun 11, 2005 | 04:55 PM
Umass021's Avatar
I just rest the code. I will see if it comes back on.
Old Jun 15, 2005 | 11:08 PM
Umass021's Avatar
I reset it and it keeps coming back on. I heard you can get fake o2 sensor's. Is that true?
Old Jun 16, 2005 | 05:31 AM
ckari's Avatar
O2 sensor question
I have 96 Maxima and the code I got was p0130 ( At Autozone ).
I replaced the Left Front O2 Sensor. Is that the correct one for the code ?
I could not find the instructions to RESET the code.
Help Please !!
Old Jun 16, 2005 | 07:01 AM
njmodi's Avatar
Again, what exact code are you getting...
Old Jun 16, 2005 | 07:02 AM
njmodi's Avatar
Help Please !!
Look in the ECU stickies.
Old Jun 18, 2005 | 06:11 AM
ckari's Avatar
http://www.brianv.net/mods/ecu/
Old Jun 18, 2005 | 07:45 AM
Black Maxima
How about the grounding strap right near the Cat/Y-Pipe connection? Does that have anything to do with the o2 sensors? Check that out...
mrc00l88
Jan 25, 2024 01:14 PM
Maxboy23
Aug 21, 2015 11:02 AM
doobadoo
Aug 15, 2015 06:43 PM
wingnut2006
Aug 15, 2015 04:16 PM
yat70458
Aug 3, 2015 01:16 PM
