Bad Bearing Sound Under the Hood
Old Jun 9, 2005 | 11:02 AM
DR-Max's Avatar
Need some help isolating a noise which sounds like a bearing going bad. It's coming from the passenger side. It could either be the alternator, the a/c compressor, or the belt tensioner. The sound is distinguishable, despite of other engine noises that you will hear. I took 2 videos, see link below. They are mp4 files to keep the file size down to a minimum while maintaining video quality. Windows Media Player 9 can play these files back, as usual Quicktime works as well.
Please right-click and save first:
Video 1 (9.2mb)
Video 2* (1.8mb)
(*I kept the camera on the crank and tensioner pulleys, the tensioner has a very slight wobble almost unnoticeable, which I am not sure if its normal).
Old Jun 9, 2005 | 11:10 AM
njmodi's Avatar
Do I get a tax break?
I saw/listened to the clips... its really tough to tell. The most likely failure is the idler pulley/tensioner.. but its hard to say that with certainty. Try to get a mechanics s***hescope or use a long piece of hose and see if you can carefully place it closer to each part and trace the source. You could also try to tighten/loosen the belt to make it louder - that might help identify the source too.
Old Jun 9, 2005 | 11:16 AM
DR-Max's Avatar
Thanks for your input. At first, I really didn't notice it until a friend of mine pointed it out. He was like, what is that sound?? Sounds like your alternator bearing is going bad. Since then, I have been constantly hearing that sound...damn him!
Old Jun 9, 2005 | 11:39 AM
joecraps's Avatar
I saw one of those idler pulleys on sale at one of the sponsors sites for $44.00 - I have replaced these before (not on my Max). You might want to go ahead get one of these if you can't isolate the noise since you did notice a slight wobble. You could try varying the tension on the adjustment bolt- it should change the pitch of the noise.
I
'll see if I can locate it again and post back.
Old Jun 9, 2005 | 11:41 AM
njmodi's Avatar
Here is a link:
http://www.trademotion.com/partlocat...5&model=Maxima
Old Jun 9, 2005 | 11:43 AM
DR-Max's Avatar
Thanks, I'll check it out.
Old Jun 9, 2005 | 11:44 AM
joecraps's Avatar
Hey better price!!! thanks njmodi $38.61
97_GXE
Sep 15, 2015 06:47 AM
Hdnseek
Sep 9, 2015 05:55 AM
jfl330
Sep 4, 2015 01:44 PM
TheMafia
Sep 4, 2015 08:26 AM
