Error Code P0402 - Pre Cat missing. Warpspeed Y-pipe
Old Jun 9, 2005 | 12:28 PM
eman88's Avatar
I need some help here, Today my "check engine light" beamed on. I took my car to the Nissan dealer and the computer came up with an error code P0402 (pre-cat is missing). I have a Warpspeed aftermarket Y-pipe and of course it doesn't have a Pre-cat installed for last 3 1/2 years with no problems till now. what are my options. I do not want to convert my car back to the stock Y-pipe (Nissan suggestion). the technican thinks my main catalytic converter might be bad and can no longer handle the load without a pre-cat installed. also my car needs an inspections in a few weeks..................I need an solution to this problem.
Old Jun 9, 2005 | 12:32 PM
smokeyone's Avatar
I've always heard that if your cat is bad, your exhaust will smell like rotten eggs. I'm willing to bet your cat has gone out.
Old Jun 9, 2005 | 12:50 PM
eman88's Avatar
Well, my exhaust doesn't smell bad at all, I looked thru the posts and error code P0402 is listed as "fuel tank Temp sensor"...........which is correct
Old Jun 9, 2005 | 12:57 PM
Bobo's Avatar
That's what the Haynes manual lists for 0402 as well.
smokeyone's Avatar
Hope its easy to change out. Good luck!!
Old Jun 9, 2005 | 01:03 PM
eman88's Avatar
I'M Sorry guys...............the Error code is P0420 not 0402............I mis-read the paper.........
Old Jun 9, 2005 | 01:11 PM
Bobo's Avatar
Scan tool trouble code P0420 is catalyst system fault (right bank). There is no CEL flash code for 0420.
Old Jun 9, 2005 | 01:32 PM
eman88's Avatar
(Right Bank ?) is that the right 02 sensor or the Cat itself. I don't have a pre-cat. if the car has been passing inspection for 3 years without a pre-cat why do I need it...
Old Jun 9, 2005 | 01:39 PM
Bobo's Avatar
I don't know much about CELs. I am just going buy the Haynes manual. The mistake 0402 code you gave eariler was the CEL code, not the scan tool trouble code listed next to it in Haynes. As I said there is no CEl 0420 code, just a scan tool trouble code.
Perhaps they have misread the code.
mvm062
Nov 30, 2020 09:00 AM
lrb6805
Sep 30, 2015 08:12 AM
junito1
Sep 23, 2015 12:14 PM
Pnjboyzz
Sep 21, 2015 12:41 PM
lrb6805
Sep 17, 2015 04:49 PM
