Vrbration through brake pedal...
Old Jun 11, 2005 | 07:43 PM
Black Maxima
Vibration through brake pedal...
What would cause a vibration through the brake pedal during harder breaking? I have all new rear brakes (rotors, pads, and calipers) and the fronts are pretty good. Would it be air in the lines? Would SS Brake lines fix it?
Yes another brake thread...AARON
Old Jun 11, 2005 | 07:56 PM
happyricefob's Avatar
V^___^V
re-surface the rotors maybe?
Old Jun 11, 2005 | 08:04 PM
njmodi's Avatar
Do I get a tax break?
Most likely warped front rotors. You say the fronts are "pretty good" - when were the pads/rotors replaced (or last turned)?
Old Jun 11, 2005 | 08:05 PM
nitromax's Avatar
usually vibration during braking is caused by warped rotors. even new will warp with repeated hard stops--the heat build up is the killer. also check for proper torque when tightening your wheels--overtightening will warp the rotors & cause vibs. and last but not least, if you have abs, hard braking will sometimes give vibs, but w/gxe i doubt you have abs.
Old Jun 11, 2005 | 08:10 PM
Black Maxima
I don't have ABS. My mom's 2000 GXE has more responsive, easier, and smoother braking. I have no idea what is wrong with my brakes. I don't know when the front rotors were turned. Oh yea and loud, growling noises when I brake hard after a high amount of speed. I feel a lot of the road when I brake.
Old Jun 11, 2005 | 09:20 PM
TrackSmart's Avatar
I've had the same symptoms in the past. The people above are correct - it's probably your front rotors. Resurface them or replace them and your troubles should disappear. Good luck.
Old Jun 11, 2005 | 09:21 PM
Black Maxima
Oh Baby, more money! Thanks for the replies!
Old Jun 11, 2005 | 09:23 PM
Black Maxima
How much does a resurfacing cost?
Old Jun 11, 2005 | 09:24 PM
JwaxMax99's Avatar
15 to 20 bucks
Old Jun 11, 2005 | 09:29 PM
TrackSmart's Avatar
Originally Posted by JwaxMax99
15 to 20 bucks
He means that's the cost to get them machined. You will have to remove and install them yourself to have that be your total cost.
Black Maxima
That's It? Where At?
Old Jun 11, 2005 | 09:30 PM
Black Maxima
AH YES......
Old Jun 11, 2005 | 09:32 PM
JwaxMax99's Avatar
Yes, that will add considerable cost to it. I always think in DIY terms.....sorry....most likely a 100 bucks.
Old Jun 12, 2005 | 12:39 AM
JPMax's Avatar
What's next!?..
Also check the slider pins on the brake calipers. Make sure they're greased and rust free.
Just helped w a brake job today where water had gotten into one of the pins and it was completely rusted inside and would not move at all.
Apr 16, 2020 05:15 AM
leatherneck
Sep 30, 2015 09:16 PM
HerpDerp1919
Sep 29, 2015 02:02 PM
Socalstillen
Sep 26, 2015 12:01 PM
