removing clear corners
Old Jun 11, 2005 | 06:06 AM
gsmith795's Avatar
i tried to take off my clear corners last night so i could get my headlights out (to do the AE mod) but the friggen things wouldn't come out. is there any trick to getting these out other than removing the one screw and pulling? i gave up because i thought i was forcing it and was about to break something...
Old Jun 11, 2005 | 06:14 AM
Doc's Avatar
Doc
Look behind them underneath the wheelwell liner. They may have been bolted in from behind to keep them from being stolen. Did you install them or get them with the car? If you didn't install them they may be secured from behind as I said. I plan to throw a nut behind mine when I can to keep them tight and from being ripped off. I hope my reply helps/makes sense.
Old Jun 11, 2005 | 06:22 AM
browne's Avatar
i just recently took it off to replace bulb. theres one screw on top and then you have to pull the light off. if you look closely you can see the screw at the bottom. you can try to use a long straight screw driver to help pull the screw out of the hole. i just pulled really hard.
Old Jun 11, 2005 | 07:01 AM
sandor's Avatar
Ahhh, confusion again...bumper lenses vs clearance lights. I thing gsmith is referring to his clearance lights beside the headlights and not his clear bumper lenses, commonly referred to as clear corners.
brownes got you covered. A little finesse is required, but take it easy, they'll come out eventually. They come out easier after the first time...but not much.
Old Jun 11, 2005 | 03:11 PM
Northern Maxima's Avatar
I had the same problem when I did the AE Mod...just be patient and try to pry them out as much as you can then pull. Just be careful, especially if your wire harness is still attached to them. When I went to paint them later on, it was much easier to pull them out. What's making them stick is the metal piece inside the far edge of each light.
Old Jun 11, 2005 | 03:18 PM
86maxima96's Avatar
I Broke OT
isn't there something like a really tight ball-and-socket joint that is holding it in? not sure if that's the technical term for it, but i'm just trying to make sense. at least that's what was on my 96
Old Jun 11, 2005 | 03:39 PM
I can't remember if there was on my 99...I don't think so. I know I had that on my headlights (made them a biatch to reinstall!) and my bumpers though.
Old Jun 11, 2005 | 04:15 PM
gsmith795's Avatar
i'll go give them a good yank and see what happens
Old Jun 11, 2005 | 09:19 PM
Fr33way™'s Avatar
Wild for Width
There is a very tight joint keeping the light in after the (obvious) screw is removed. You WILL be able to pull it out. I would just gradually increase the amount of pulling force each time.
Old Jun 12, 2005 | 02:36 AM
maximazation's Avatar
taking mine off, just put a piece of cloth in between the corners lights and pry it out, and POP it comes out.
Apr 16, 2020 05:15 AM
RealityCheck
Oct 2, 2015 06:34 PM
uttadms31
Sep 30, 2015 05:24 AM
jaydot901
Sep 29, 2015 01:18 PM
