Creaking center console components = chassis flex?
Old Jun 14, 2005 | 07:33 AM
Who's Avatar
Who
When I take sharp corners the plastic components in the center console creaks so I was wondering if it may be related to the chassis flexing? I think some of the felt cloth must have come out from between the components causing them to make more noise. Also I think it got worst after I lowered the car....maybe now that the springs aren't as flexible the chassis is taking more strain?
Anyone noticed if installing the strut tower bar reduces this noise?
Old Jun 14, 2005 | 09:09 AM
happyscrappy's Avatar
my creakin/squeakin was never really that bad, but it did get somewhat better after i installed the FSTB. i saw another thread on here a while ago about Warpspeed's Sub-Frame Connector, IIRC it would help more than the FSTB in eliminating squeaks... but don't hold me to it.
Old Jun 14, 2005 | 10:38 AM
Black Maxima
Add more felt tape. That will definatly solve the problem of the creaking. Pin point all your problem areas and add felt tape.
Old Jun 14, 2005 | 10:45 AM
jaedaliu's Avatar
There's a TSB in the stickies that tells you how to take apart the different parts of the car that might be making squeeks, where to put felt tape, and how to get your car quiet again.
Old Jun 14, 2005 | 10:46 AM
Half_Lunatic's Avatar
I dont know if you've checked the a-pillars or not, but those seem to be the problem on most cars. The problem is that the a piller piece rubs against the dash. Like others have suggested felt tape will fix that up.
Old Jun 14, 2005 | 10:51 AM
Black Maxima
YUP! I fixed the A-Pillars, every easy to fix them!
Old Jun 14, 2005 | 09:00 PM
Who's Avatar
Who
A-Pillars are the ones on the side of the windscreen I assume? I was planning on using the felt tape but I was just looking for a way to confirm if the FSTB actually works. Thanks for the advice.
Old Jun 15, 2005 | 07:15 AM
Black Maxima
Get some felt tape, take off the A-Pillars and stick it on the part of the A-Pillar that hits the dash. It's kind of hard to get at it and the A-Pillar might not slide in as good, but it's worth it!
Old Jun 15, 2005 | 08:45 AM
bthe's Avatar
I find that it helps to remove the parts that are creaking, and apply felt tape between the contact surfaces of the moving parts.
Old Jun 15, 2005 | 09:46 AM
nismology's Avatar
Do you bother reading posts in a thread?? Almost everybody that posted before you already said the same thing.
Old Jun 15, 2005 | 09:50 AM
jaedaliu's Avatar
He was tossing in repeated info to get to 15 posts. (just like I am)
but let me actually help a little bit.
http://www.jatan.net/tsbs/056820.pdf
the TSB that has the dismantle instructions for squeek-prone parts.
Old Jun 15, 2005 | 09:55 AM
Black Maxima
I think I'm all good with the sqeak tape. All I need to fix is the top left corner of the center air vents. But then again, a lot of other parts make noise when my bass hits. I have no idea on how to fix the top left corner of the center air vents.
Apr 16, 2020 05:15 AM
gigabyte
Jan 6, 2017 06:05 PM
RealityCheck
Oct 2, 2015 06:34 PM
