tune up
Old Jun 14, 2005 | 11:36 PM
Nissan2k5's Avatar
tune up
alright i wrote in a previous post about my car being a little sluggish so i decided to do a full tune up myself. is there a write up on the steps i should take? also about how much will this run me? thanks for the info guys
Old Jun 15, 2005 | 12:14 AM
dayglo's Avatar
how to clean your throttle body (TB)
read up in the stickies.
#1 how-to shows you how to clean your IAC valve, follow the links in the same post for your oil change spark plugs and whatever
tune up's are always DIY, its the easy work save the machanic bills for the tough jobs
Old Jun 15, 2005 | 02:10 AM
smokeyone's Avatar
http://web.archive.org/web/200210212...k_service.html
60K Tuneup List
Old Jun 15, 2005 | 07:01 AM
jml762's Avatar
Proper spark plug gap for NGK V-Power Copper
I replaced the spark plugs yesterday. I did not change the gap as set at the factory (which was 0.040), since my replaced original platinum plug was 0.040. From the above posting, I found that the proper gap is 0.044. Do you think that I need to redo the job to change the gap from 0.040 to 0.044 or is it OK as it is?
Old Jun 15, 2005 | 07:10 AM
Bobo's Avatar
I believe the gap is 0.039 to 0.043, so you are likely within spark plug gap tolerances.
Old Jun 15, 2005 | 07:11 AM
Iron Scimitar's Avatar
Tha Snatcher
whats the next tune after 60k? is it 100k or 120k?
Old Jun 15, 2005 | 07:26 AM
Bobo's Avatar
90K.
Major service every 30K, with OEM spark plugs at 60K, 120K etc. Automatic tranny probably should be drained & filled at 30K, flushed @60, repeat cycle.
Probably should take a good look at belts and hoses @ 90K if they haven't been changed. Same goes for CV boots.
Old Jun 15, 2005 | 07:56 AM
Loe max's Avatar
^^Add to that, make sure you flush the coolant, brakes, power steering ect... Those are things that people forget.
Old Jun 15, 2005 | 08:10 AM
Bobo's Avatar
Also may want to replace transaxle gear oil if a 5-speed. Change fuel filter, air filter etc. etc.
litch
123
Jan 4, 2024 07:01 PM
aw11power
Oct 10, 2021 04:57 AM
Socalstillen
Sep 26, 2015 12:01 PM
zzznightmarezz
Sep 21, 2015 06:32 PM
Maxboy23
Sep 4, 2015 06:04 PM
